PatchInjection: Initial Particle Position
Old   April 16, 2014, 17:55
Default PatchInjection: Initial Particle Position
India
mayank.dce2k7 is on a distinguished road
I wanted to use patchInjection model for my particle simulation. I want to know what is the initial starting position of parcels/injectors at the specified patch. It is uniformly distributed or parabolic or base on some random function.
From the file PatchInjection.H:
 //- List of cell labels corresponding to injector positions
        labelList cellOwners_;
I understood initial position of parcels/injectors is defined by cellOwners_
In file PatchInjection.C:
cellOwners_ = patch.faceCells();
This tells me position of injectors is taken at face cells.
What I am unable to interpret is if number of parcel/injectors specified are less than no. of cell centers than how the parcels/injectors position is decided on given patch?
mayank.dce2k7 is offline   Reply With Quote
Old   October 6, 2022, 12:11
Default base patch injection - number of parcel/injectors relation to number of cell center
CFD_Bz is on a distinguished road
Originally Posted by mayank.dce2k7 View Post
Hello mayank.dce2k7
I know this thread was written long time ago (in april 2014) !
However i would still try to ask you (Or anyone else) if you have found an answer for your quesion !?
Thanks in advance,
Cordially
CFD_Bz is offline   Reply With Quote
Divergence only by lengthening of simulated geometry, buoyantPimpleFoam arvhult OpenFOAM 16 March 29, 2014 17:03
Courant-number explodes after a lon while (icoFoam) Rody- OpenFOAM Running, Solving & CFD 6 January 29, 2014 04:27
Extremely slow simulation with interDyMFoam jrrygg OpenFOAM Running, Solving & CFD 9 April 23, 2013 10:14
pisoFoam - unstable pressure residual Industrial_CFD OpenFOAM Running, Solving & CFD 21 February 24, 2013 15:39
Interfoam blows on parallel run danvica OpenFOAM Running, Solving & CFD 16 December 22, 2012 02:09
