Solver for superfluid helium based on Laplacian Foam |
May 19, 2014, 12:10 |
Gennaro
Rep Power: 12 |
I'm working on a superFluid helium solver based on Laplacian Foam. The difference between LaplacianFoam and my solver is that the thermal conductivity k is replaced with keff which is a function of the gradient of the temperature. This model was developed a few years ago and it is used in the cryogenic industry, but no one implemented it on OpenFOAM yet. I'm trying to do it although I'm relatively new to OpenFOAM programming and C++ programming. So I created the solver, which compiles but crashes returning the following error: Create time Create mesh for time = 0 Reading field T Reading thermophysicalProperties Selecting thermodynamics package { type heSolidThermo; mixture pureMixture; transport polynomial; thermo hPolynomial; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Reading Alambda Reading Slambda Reading Tlambda No finite volume options present Radiation model not active: radiationProperties not found Selecting radiationModel none Calculating temperature distribution SIMPLE: no convergence criteria found. Calculations will run for 0.01 steps. Time = 1e-06 #0 Foam::error:rintStack(Foam::Ostream&) in "/afs/cern.ch/project/cfd/OpenFOAM/SLC6/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/afs/cern.ch/project/cfd/OpenFOAM/SLC6/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so" #2 at sigaction.c:0 #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/afs/cern.ch/project/cfd/OpenFOAM/SLC6/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so" #4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/afs/cern.ch/user/g/gbozza/OpenFOAM/gbozza-2.3.x/platforms/linux64Gcc46DPOpt/bin/laplacianFoamCustom" #5 at laplacianFoamCustom.C:0 #6 in "/afs/cern.ch/user/g/gbozza/OpenFOAM/gbozza-2.3.x/platforms/linux64Gcc46DPOpt/bin/laplacianFoamCustom" #7 __libc_start_main in "/lib64/libc.so.6" #8 in "/afs/cern.ch/user/g/gbozza/OpenFOAM/gbozza-2.3.x/platforms/linux64Gcc46DPOpt/bin/laplacianFoamCustom" Floating exception (core dumped) I don't understand what SIMPLE: no convergence criteria found means. Please find in attachment the solver and a case. Can you please help? Thanks Best regards |
October 3, 2017, 03:56 |
Libor Macek
Rep Power: 9 |
Hello Gennaro,
Did you make any progressi in this problem? I am interested in computation with superfluid. Best regards. Libor |
October 5, 2017, 08:01 |
Cyprien
Rep Power: 18 |
Dear Libor,
please have a look at some papers we published with HellFOAM our superfluid helium simulator with OpenFOAM: http://www.sciencedirect.com/science...10465514003415 https://journals.aps.org/prl/abstrac...ett.118.074506 http://oatao.univ-toulouse.fr/11935/...aine_11935.pdf The first one described the algorithm we developed in OpenFOAM and some validation test cases. We uploaded the source code and you can download it here https://github.com/csoulain/HellFOAM I haven't upgrade the code with the new OpenFOAM release, but I am sure you can do it easily. Cheers, Cyprien |
October 26, 2017, 03:18 |
Libor Macek
Rep Power: 9 |
Thank you for advice
laplacianfoam, simple algorithm |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Pressure based and Density based Solver | Xobile | Main CFD Forum | 39 | August 19, 2020 06:04 |
[OpenFOAM] Take derivative of mean velocity in paraFoam | hiuluom | ParaView | 13 | April 26, 2016 06:44 |
Derivative of velocity and mean velocity | hiuluom | OpenFOAM Post-Processing | 1 | May 29, 2015 23:42 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
