Difference between phi and phiv
Like Tree2Likes
  • 1 Post By kettnera
  • 1 Post By mturcios777
Old   May 24, 2014, 10:56
Question Difference between phi and phiv
yehanyu
yhy20081016 is on a distinguished road
Hi, everybody.
Usually, for many solvers, in "createFields.H", the face-flux is created by including the header file "createPhi.H". For compressible flows, the header "compressibleCreatePhi.H" is used instead. However, I observed that in the solver "cavitatingFoam", a third header named "createPhiv.H" is used. I cannot understand the difference between "phi" and "phiv". Does anyone has an idea? Thank you very much.
yhy20081016 is offline   Reply With Quote
Old   August 21, 2014, 09:20
Andrew Kettner
kettnera is on a distinguished road
Originally Posted by yhy20081016 View Post
Hi, everybody.
Reviewing both createPhi.H and createPhiv.H the files appear to be identical other than using phiv rather than phi.
lpz456 likes this.
kettnera is offline   Reply With Quote
Old   August 21, 2014, 12:46
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Not knowing much about cavitatingFoam but quickly reviewing the solver, it appears phiv is the flux for the vapour fractin. This makes sense as you have a two phase flow you are solving for and each phase will have a different flux.
lpz456 likes this.
mturcios777 is offline   Reply With Quote
Old   August 21, 2014, 12:52
Andrew Kettner
So the phiv and phi are identical but intended for different phases. I have not done multiphase work and the answer may be obvious if I had, but how does the code distinquish between the phases. Like I said earlier the code is identical. I will take a look at cavitatingFoam to see I can figure it out.
flux, phi, phiv
MSHArequest for surfaceScalarField phi from objectRegistry msha OpenFOAM Running, Solving & CFD 11 March 21, 2014 03:35
