Calculation of patch area in a 2D geometry
Old   June 17, 2014, 12:22
Default Calculation of patch area in a 2D geometry
Luca
marluc is on a distinguished road
Dear All,
I have a very simple 2D channel flow of 1 unit length height.
When using the following code to determine the inlet patch area I get the value 0.25 instead of the expected value of 1:
scalar area = gSum(mesh.magSf().boundaryField()["inlet"]);
Info << "Inlet area: " << area << endl;
Can anyone explain explain me the reason, i.e. how is the face area evaluated for a 2D case?
Thank you in advance,
Luca
marluc is offline   Reply With Quote
Old   July 11, 2014, 11:19
Smile
Vignesh
vigneshTG is on a distinguished road
Originally Posted by marluc View Post
Dear All,
Luca
Luca !!
I think you are calculating area not the height. Even in 2D, there is one cell thickness along z direction. Check what is the length you have given in z direction in blockMesh and divide the area by this length, you will get the height !!
Hope this helps !!
Thanks and Regards
Vignesh
vigneshTG is offline   Reply With Quote
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 11:25
[Commercial meshers] Fluent msh and cyclic boundary cfdengineering OpenFOAM Meshing & Mesh Conversion 48 January 25, 2013 03:28
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[mesh manipulation] Using createPatch in place of couplePatches sripplinger OpenFOAM Meshing & Mesh Conversion 8 November 13, 2009 07:14
Surface integral calculation by undefined area Bloshchitsyn Vladimir CFX 0 November 18, 2007 22:19
