wall clock time for each processor
Like Tree1Likes
  • 1 Post By openfoammaofnepo
Old   June 18, 2014, 05:43
Default wall clock time for each processor
openfoammaofnepo is on a distinguished road
Dear All,
I am trying to know the wall clock time for each processor. For instance, the following code:
            // --- PIMPLE loop
            while (pimple.loop())
                #include "UEqn.H"
                #include "YEEqn.H"
                // --- Pressure corrector loop
                while (pimple.correct())
                    #include "pEqn.H"
                if (pimple.turbCorr())
                    turbulence->correct();
I would like to know for each processor, how long is the wall clock time to calculate the following:
 #include "UEqn.H"
I noticed that in the OF, we always use
runTime.elapsedClockTime()
to return the wall clock time for each time step, but this is not for one processor.
Does anybody know something about how to output the wall clock time for each processor?
OFFO
openfoammaofnepo is offline   Reply With Quote
Old   June 23, 2014, 06:47
In Openfoam, I found that we can use the following two functions to the wall clock time and cpu time:
time_t Foam::clock::clockTimeIncrement() const
double Foam::cpuTime::cpuTimeIncrement() const
When I add them into the code, I need to test both - the wall clock time and cpu time time. But I found that if put these functions together like :
runTime.cpuTimeIncrement();
runTime.clockTimeIncrement();
In this case, the function clockTimeIncrement() always returns the zero wall clock time. This maybe caused by the fact that these two functions are executed consecutively, i.e. newTime_-LastTime = 0. So I cannot get the wall clocktime in this way.
Do you have some suggestions if I indeed to extract the both wall clock time and cputime? Thank you very much.
Tushar@cfd likes this.
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 07:56
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
