k-omega SST SAS High Wavenumber Damping Limiter
Like Tree2Likes
  • 1 Post By PonchO
  • 1 Post By PonchO
Old   September 16, 2014, 09:26
Default k-omega SST SAS High Wavenumber Damping Limiter
Christoph Kratzsch
PonchO is on a distinguished road
Hello to everyone ,
i am trying to use the k-omega SST SAS model for my simulation.
By taking a look into the source code i recognized that the OpenFOAM-Version is very different from current versions proposed in the literature.
Besides the different formulation of the P_{SAS} term in the \omega-equation, the von-Karman length in newer papers is something like this:
L_{vK}=max\left(\frac{\kappa\,S_2}{|\nabla^2\underline{u}|},HWDL\right)
However, the OpenFOAM-2.3.x version reads
HWDL=C_{s}\Delta
whereas Egorov and Menter [1] propose the following:
HWDL=C_s\,\Delta\sqrt{\frac{\kappa\zeta_2}{\frac{\beta}{C_{\mu}}-\alpha}}.
Question 1: Did i understand it right, that OpenFOAM does not include the high wavenumber damping correctly? And what do you suggest for implementation?
The latter HWDL is based on the Smagorinsky SGS.
But taking a look into [2] the authors say, that a Smagorinsky SGS might not work well.
They propose, that it is better to construct a HWDL from a WALE SGS model.
Unfortunately, i don't have access to the reference [23] they give in [2].
Question 2: What do you think about that? Does this HWDL has that big impact on the results?
Maybe someone is familiar with the model as well as its different versions and brings a little bit light into the darkness .
Best regards,
Christoph
[1] Egorov, Y., and F. Menter. "Development and application of SST-SAS turbulence model in the DESIDER project." Advances in Hybrid RANS-LES Modelling. Springer Berlin Heidelberg, 2008. 261-270.
[2] Menter, F. R., and Y. Egorov. "The scale-adaptive simulation method for unsteady turbulent flow predictions. Part 1: Theory and model description." Flow, Turbulence and Combustion 85.1 (2010): 113-138.
jherb likes this.
PonchO is offline   Reply With Quote
Old   October 29, 2014, 07:15
Joachim Herb
jherb is on a distinguished road
Did you find any answers to your questions?
(Your missing reference can be found as printed book in several libraries in Germany, so you should be able to order it as "Fernleihe" from any university library: http://kvk.ubka.uni-karlsruhe.de/hyl...bit_redirect=1)
jherb is offline   Reply With Quote
Old   October 29, 2014, 09:18
Christoph Kratzsch
Hi Joachim,
i just used the plain OpenFOAM model for my first SAS simulations. The next step is to implement the standard model from CFX and Fluent into OpenFOAM, which is based on a Smagorinsky-like HWDL. I will check the deviations by simulating a wake flow behind a triangular cylinder [1].
Afterwards, i will try to couple the model with the WALE-SGS or the Vreman-SGS. If you know a good testcase for validation of flows, where the turbulent viscosity should vanish in certain regions, then feel free to reply :-).
Its just a side project. So it may take some time ;-).
Best regards.
Christoph
[1] Zhang, Xing, and Blair Perot. "Turbulent Vortex Shedding From Triangle Cylinder, Using the Turbulent Body Force Potential Model." Proceedings of ASME Fluids Engineering Division, FEDSM2000-11172, Boston, Massachusetts (2000).
mj.foamer likes this.
Old   October 29, 2014, 09:20
Christoph Kratzsch
So i don't found any answers regarding the different implementations...;-)
Old   March 16, 2016, 06:41
kingjewel1 is on a distinguished road
Hi guys,
Any updates on this one?
kingjewel1 is offline   Reply With Quote
Old   March 21, 2016, 12:01
Pekka Pasanen
zordiack is on a distinguished road
I recently made one implementation based on the 2010 papers, you can check it out here:
http://www.cfd-online.com/Forums/ope...nce-model.html
EDIT: Just noticed you are using LES, never mind
zordiack is offline   Reply With Quote
overshooting of Omega in SST komega using simpleFoam cm_jubayer OpenFOAM 2 June 7, 2020 12:52
High curvature 90 degree bend using SST, eddy viscosity drop?? tinab0binuh Main CFD Forum 0 August 22, 2014 17:26
Boundary Conditions for k omega SST dancfd OpenFOAM Pre-Processing 0 June 9, 2011 23:25
k Omega SST SAS for OpenFOAM 1.5??? barath.ezhilan OpenFOAM Running, Solving & CFD 3 June 2, 2010 07:41
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
