Lagrangian equation in parcel.C
Like Tree3Likes
  • 3 Post By zarox
Old   October 7, 2014, 04:37
Default Lagrangian equation in parcel.C
Cluap is on a distinguished road
Hi everybody,
I'm using OpenFOAM 1.7 with dieselSpray, in order to model gasoline droplets in a turbulent air flow with an Euler approach for the carrier phase and a lagrangian appproach for the droplets.
When I look at the lagrangian equation in parcel.C, I see :
U() = (U() + (timeRatio*Ucorr)+ gcorr*dt)/(1.0 + timeRatio); (Eq 1)
where U() is the droplet velocity, Ucoor the velocity of the gas seen by the droplet and timeRatio=dt/tauMomentum whith tauMomentum the droplet relaxation time.
But this looks very different from any classical lagrangian equation which should be something like :
dUp/dt = (Ug - Up)/Tp + g (Eq 2)
where Up is the velocity of the droplet, Ug the velocity of the gas seen by the droplet ant Tp the droplet relaxation time.
Discretized it should be something like :
U() = (1 - timeRatio)*U() + (timeRatio*Ucorr) + gcorr*dt (Eq 3)
So why does OpenFoam use Eq 1 instead of Eq 3 ?
Any help would be very appreciated.
Thank you.
Cluap is offline   Reply With Quote
Old   February 19, 2015, 10:43
Default Lagrangian particle velocity integration
Emeline Noel
zarox is on a distinguished road
Hi Cluap,
Perhaps, you find the answer but I was asking my self the same question and found the solution so I would like to share with other and also to keep memories of the solution. Perhaps, it is obvious for personn who work in the lagrangian world.
First, I should say I was not aware of the tauMomentum so the Euler integration for parcel of openfoam was very strange for me. But I find that the drag force is can be express thanks to the tauMomentum :
tauMomentum = mp*|Uc-Up|/|Fd|
* Uc : carrier phase velocity
* Fd : Drag Force
* Up : particle velocity
* mp : mass of the particle
So,
dUp/dt = Fd/mp + Fg/mp (1)
Using tauMomentum : Tp
dUp/dt = (Ug - Up)/Tp + g (2)
From there, I think the key is to know that in (2) OpenFOAM use the particle velocity at t+dt
Briefly, taking 1/Tp = A
Up(t+dt) = Up(t) + A*dt*(Ug-Up(t+dt)) + Fg*dt
So,
Up(t+dt) = Up(t) + (A*dt*Ug+Fg*dt)/(1+A*dt)
A*dt = timeRatio
So you find the equation in OpenFOAM :
May it can help someone!
Tchuss
zarox is offline   Reply With Quote
dieselspray, lagrangian, parcel, particle
Some problem of "Qcriterion.mcr& yuyuxuan Tecplot 9 February 12, 2016 03:27
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 19:53
Need help:about energy equation in CFX Stein CFX 4 July 2, 2009 22:31
Boundary conditions in a Poisson's equation? vincent Main CFD Forum 4 April 16, 1999 02:19
