backport interPhaseChangeDyMFoam to OpenFoam 2.1.x
Old   November 6, 2014, 06:59
Default backport interPhaseChangeDyMFoam to OpenFoam 2.1.x
BigPapi34 is on a distinguished road
Hi there,
Having done some work in OpenFoam 2.1.x using single phase solvers, I am looking to keep this version but add/compile interPhaseChangeDyMFoam which has been added to the more recent releases. Can anyone advise the best approach of doing this, if there are any obvious issues or in fact if it is not possible.
Thanks in advance.
BigPapi34 is offline   Reply With Quote
Old   November 8, 2014, 13:32
Nima Samkhaniani
nimasam is on a distinguished road
the much easiest way is to have two version of together
or
you can simply comile new solver under your working version and find inconsistent libraries and try to modify it
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   November 9, 2014, 08:58
I have quite a lot of things I wish to stay the same so would be using 2.1.x in this particular instance.
I am going download the interPhaseChangeDyMFoam solver, review the differences between the 'old' and 'latest' versions of the standard and attempt to compile and get it working. Thanks for confirming the thought process, hopefully it works!
interphasechangedymfoam, openfoam 2.1.x
Multiple OpenFOAM versions on one machine eric.m.tridas OpenFOAM Installation 19 February 15, 2014 11:09
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 05:34
Same SimpleFOAM Case converges with openFOAM 2.1 but diverges with openFOAM 2.0.1 alsdia OpenFOAM Running, Solving & CFD 3 October 22, 2012 11:25
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
