backport interPhaseChangeDyMFoam to OpenFoam 2.1.x |
November 6, 2014, 06:59 |
Rep Power: 14 |
Hi there,
Having done some work in OpenFoam 2.1.x using single phase solvers, I am looking to keep this version but add/compile interPhaseChangeDyMFoam which has been added to the more recent releases. Can anyone advise the best approach of doing this, if there are any obvious issues or in fact if it is not possible. Thanks in advance. |
November 8, 2014, 13:32 |
Nima Samkhaniani
Rep Power: 24 |
the much easiest way is to have two version of together
or you can simply comile new solver under your working version and find inconsistent libraries and try to modify it
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
November 9, 2014, 08:58 |
Rep Power: 14 |
I have quite a lot of things I wish to stay the same so would be using 2.1.x in this particular instance.
I am going download the interPhaseChangeDyMFoam solver, review the differences between the 'old' and 'latest' versions of the standard and attempt to compile and get it working. Thanks for confirming the thought process, hopefully it works! |
interphasechangedymfoam, openfoam 2.1.x |
Multiple OpenFOAM versions on one machine | eric.m.tridas | OpenFOAM Installation | 19 | February 15, 2014 11:09 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
Same SimpleFOAM Case converges with openFOAM 2.1 but diverges with openFOAM 2.0.1 | alsdia | OpenFOAM Running, Solving & CFD | 3 | October 22, 2012 11:25 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
