waveDyMfoam building error on OF 2.3.x
Old   November 26, 2014, 16:09
Default waveDyMfoam building error on OF 2.3.x
jmf
Jean-Michel FONTAINE
jmf is on a distinguished road
Dear all
I attempt to couple waveFoam and interDyMfoam, as described here :
https://sites.google.com/site/jordim...ic-mesh-motion
wavesfoam builds and run easily (many thanks to the developpers !). wavesFoam build directory is : /OpenFOAM/<user>/applications/utilities/waves2Foam/applications/solvers/solvers230/waveFoam
I copied 'interDyMfoam' in there, renamed it as 'waveDyMFoam', modified 'waveDyMFoam.C' according the instructions above.
'waveDyMfoamMake/options' content is:
EXE_INC = \
    -I.. \
    -I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/transportModels \
    -I$(LIB_SRC)/transportModels/incompressible/lnInclude \
    -I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \
    -I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \
    -I$(LIB_SRC)/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/dynamicMesh/lnInclude \
    -I$(LIB_SRC)/dynamicFvMesh/lnInclude \
    -I./../../../../../src/waves2Foam/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/fvOptions/lnInclude \
    -I$(LIB_SRC)/sampling/lnInclude
EXE_LIBS = \
    -limmiscibleIncompressibleTwoPhaseMixture \
    -lincompressibleTurbulenceModel \
    -lincompressibleRASModels \
    -lincompressibleLESModels \
    -lfiniteVolume \
    -ldynamicMesh \
    -ldynamicFvMesh \
    -ltopoChangerFvMesh \
    -lmeshTools \
    -lfvOptions \
    -lsampling \
    -L$(FOAM_USER_LIBBIN) \
    -lwaves2Foam
The wmake log file is:
SOURCE=waveDyMFoam.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I.. -I/home/nous/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/twoPhaseMixture/lnInclude -I/home/nous/OpenFOAM/OpenFOAM-2.3.x/src/transportModels -I/home/nous/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/incompressible/lnInclude -I/home/nous/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/interfaceProperties/lnInclude -I/home/nous/OpenFOAM/OpenFOAM-2.3.x/src/turbulenceModels/incompressible/turbulenceModel -I/home/nous/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/home/nous/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/home/nous/OpenFOAM/OpenFOAM-2.3.x/src/dynamicMesh/lnInclude -I/home/nous/OpenFOAM/OpenFOAM-2.3.x/src/dynamicFvMesh/lnInclude -I./../../../../../src/waves2Foam/lnInclude -I/home/nous/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/home/nous/OpenFOAM/OpenFOAM-2.3.x/src/fvOptions/lnInclude -I/home/nous/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -IlnInclude -I. -I/home/nous/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/nous/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/waveDyMFoam.o
The compilation error is :
waveDyMFoam.C: In function ‘int main(int, char**)’:
waveDyMFoam.C:128:21: error: ‘mixture’ was not declared in this scope
waveDyMFoam.C:141:13: error: ‘mixture’ was not declared in this scope
The waveDyMFoam.C is attached
I've got OF 2.3.x from Git
I would be grateful for any help
Best wishes
Jean-Michel
jmf is offline   Reply With Quote
Old   February 28, 2015, 14:37
carlos
CFD-Palma is on a distinguished road
Hi Jean-Michel
I have the same problem with OF231 trying to compile waveDyMFoam.
Apparently, mixture did not exist before and was Interface.
With interface it compiles but it does not work, so I can not help here, but wait for someone knowledgeable to help.
Niels already said he will only actualise to 2.4.0 as there are too many changes, I understand him.
Regards,
Carlos.
CFD-Palma is offline   Reply With Quote
Old   March 3, 2015, 18:07
jmf
Thanks Carlos for this info
I still need in waveDyMFoamn so I will be patient
Best wishes
Jean-Michel
Old   March 4, 2015, 06:08
carlos
Hi Jean-Michel,
I have solved, see this post:
http://www.cfd-online.com/Forums/ope...tml#post533884
building, interdymfoam, wavefoam
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 14:56
Paraview Compiling Error (OpenFOAM 2.1.x + openSUSE 12.2) sfigato OpenFOAM Installation 22 January 31, 2013 10:16
Scaling down a building faisal_durr Main CFD Forum 5 July 7, 2011 12:02
Scaling down a building faisal_durr ANSYS Meshing & Geometry 1 July 6, 2011 14:39
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
