LAPLACIAN FOAM for solid/fluid region in a slab
Like Tree6Likes
Old   April 26, 2015, 09:37
Nicolas Thiers
nthiers is on a distinguished road
Hi arslan, hace you tried defining dt field and use setField utility to start dt field with different values for your two regions.
nthiers is offline   Reply With Quote
Old   April 26, 2015, 09:42
Arslan Arshad is on a distinguished road
no i dont think so
Arslan Arshad is offline   Reply With Quote
Old   April 26, 2015, 09:43
by the way how to do it.... i am new to openfoam
Old   April 26, 2015, 10:05
Nicolas Thiers
Take a look at tutorial/multiphase/interfoam/system/setFieldsDict
There is used to initialize alpha field, but for your case just change alpha for dT and the boxToCell parameters to fit with your regions like this
Lets said that for the left region you need dt=0.1 and for the right dt=0.3
First set default value dt=0.1
Then in the boxToCell put the coordinates of the right region and inside put dt=0.3
Then use:
setField
yourSolver
Arslan Arshad likes this.
Old   April 26, 2015, 10:28
my geometry is 3d
left region (0.5x0.5x0.5) m
same is the dimension of right region
what is meant by boxToCell and how
what should be the coordinates.......please can you elaborate with example?
Old   April 26, 2015, 10:36
and is there any need to change the DT in "transportproperties"
and is there any need of making "DT" named file as "T" in folder named "0"
Old   April 26, 2015, 10:47
Nicolas Thiers
First of all you have to change the dt propertie to a volScalarField like mostafa said before.
Then you have to add the dt and T files to your 0 folder
(this was explained in a tutorial called "add temperature to icofoam" take a look on it, will be very helpful)
For the boxToCell utility, I have never used before soy I don't know exactly how to put the coordinates, for that you should search for your own, there is a interfoam tutorial on internet where there explain how to set it.
Sorry I can't help more with that
Old   April 26, 2015, 11:06
i figured it out
boxToCell
(Min. Boundary coordinates) (Max. Boundary Coordinates);
you have to put minimum boundary coordinates and for maximum
that can be known by analysing your volume in software you are using for making geometry (in my case it is gambit)
thanks for the reply
will tell you about the solver after compiling it
Old   April 26, 2015, 12:17
is there any need for "DT" in folder "0"?
if yes then what should be the boundary conditions?
Old   April 26, 2015, 12:35
Nicolas Thiers
Yes it's necessary but how you arn't solving any transport equation for dt you don't need any boundary conditions but anyway the solver may ask you for them, in that case set any boundary condition fo dt like zerogradient
Old   April 26, 2015, 16:50
i tried the solver but it gives the same value of "DT" over both regoins....
any suggenstions?
Old   April 26, 2015, 17:51
Nicolas Thiers
can you show me yoru solver, your createFields.h, a schemes of your 0 folder and your setFieldsDict please
Old   April 26, 2015, 18:24
thank you for the help but i sorted it out
you have to rename your file "DT.org" instead of "DT"
and then in terminal go to the address of the solver folder
and type
"cp -r 0/DT.org 0/DT"
this will make the DT file. in the "0 folder"
then type the command "setFields".
you are all set to go......
Old   April 26, 2015, 18:28
Nicolas Thiers
thats right, let me know about your results.
Old   April 27, 2015, 04:11
it shows infinity when i put the condition on the right side of domain (type zeroGradient)
but gives the solution when i give the boundary condition (type fixedValue) on the right face.
and i want the solver to calculate the value at the right face.....where am i wrong?
THANKS in advance
Old   May 12, 2015, 23:27
Nicolas Thiers
Arslan sorry for the delay, am also doing some test with a problem like that and i figure that when use
div(phi,T) Gauss linear;
in the system/fvSchemes the T field diverges, but when use
div(phi,T) Gauss vanLeer;
it works fine in mi case, try it and let me know if it works
Old   February 16, 2017, 04:11
Alejandro
ancolli is on a distinguished road
Did u manage to solve the problem?
Can you post all the code?
Thanks in advance
ancolli is offline   Reply With Quote
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
[OpenFOAM] Take derivative of mean velocity in paraFoam hiuluom ParaView 13 April 26, 2016 06:44
laplacian foam simulating diffusion through a porous media mcdonalds OpenFOAM Running, Solving & CFD 1 February 1, 2015 16:51
[Gmsh] GmshToFoam FOAM FATAL ERROR faces deallocated Tobias Prousa (Prousa) OpenFOAM Meshing & Mesh Conversion 14 January 31, 2012 10:45
Nonconvergence in a multiple region Laplacian problem kmurphy OpenFOAM Running, Solving & CFD 4 June 8, 2006 04:40
