Tabulated fluid thermo model
Like Tree9Likes
Old   January 5, 2016, 04:43
Luka Denies
LukaD is on a distinguished road
First and foremost, I have pushed some changes to the repository lately. The most important one is that I no longer use the built-in method to evaluate the temperature T from enthalpy h. Instead, I do a reverse interpolation of the enthalpy table to obtain the correct temperature. This fixes the problem of non-converging temperature, which can occur at near-critical conditions because of the sharp temperature gradients. However, the resulting thermophysical library no longer contains the standard thermos.
Originally Posted by hcl734 View Post
Is it also possible to define just one property using the tables and the others let's say using icoPolynomial?
At the moment this is not possible. However, this would be fairly easy to implement for yourself. Either generate a very simple table yourself (e.g. with only two pressures), or add a new makeThermo in psiThermos.C
Did you test this Utility with chtMultiRegionSimpleFoam?
Yes, I tested it with this solver and later modified the solver for my own use.
LukaD is offline   Reply With Quote
Old   January 7, 2016, 05:16
chriss85 will become famous soon enough
We also need to keep in mind that some solvers might not be developed to support a pressure dependence of the fluid properties. So in general it is necessary to look into the algorithm of a solver to see if all terms are considered and if the properties are updated when the pressure changes. It's possible that some solvers don't update their properties by calling thermo.correct() in the pressure corrector loop or elsewhere. If pressure dependent properties are accessed in this case they will be from a previous iteration or time step and this might lead to numerical errors.
chriss85 is offline   Reply With Quote
Old   December 15, 2020, 07:04
Cuber Jeo
FluidDynamicsTheory is on a distinguished road
Hi Luka,
I want to know what version of Ubantu and OpenFOAM you used? I can't run the "smartGenerator.py“ and "thermoClass.py" in Ubantu 20.04 wih OpenFOAMv2006 and OpenFOAM8. I will appreciate if you can help me!
FluidDynamicsTheory is offline   Reply With Quote
Old   December 15, 2020, 13:34
Luka Denies
I'm not sure, it is a long time ago. Probably OpenFOAM 3 and Ubuntu 14.4.
Old   December 21, 2020, 08:42
Cuber Jeo
Thank you very much for you reply! I’ll try it!
Old   December 25, 2020, 03:38
Cuber Jeo
Originally Posted by chriss85 View Post
Table structure goes like this:
(x1 (y11 z11)(y12 z12)...)
(x2 (y21 z21)(y22 z22)...)
You will have to write these files yourself using a small script. I could provide a python script if you have an input csv file like this:
0 x1 x2 ...
y1 z11 z21 ...
y2 z21 z22 ...
I don't remember the exact ordering from my head, you would have to check that yourself.
Hi, chriss,
You have ever said a python script can generate a table structure if we have an input csv file like this:
0 x1 x2 ...
y1 z11 z21 ...
y2 z21 z22 ...
The table structure goes like this:
Could you provide a python script example to me? I have a problem to generate the files myself. I'll appreciate if you can help me!
Old   December 25, 2020, 04:11
Cuber Jeo
Originally Posted by LukaD View Post
I have programmed a new thermo model to use tabulated fluid properties instead of the existing models. The model covers an equation of state, the thermodynamic properties as well as transport properties. All of these must be defined by the user in two-dimensional (p,T) tables that are then interpolated.
This feature is especially useful when simulating supercritical fluids that have rapidly changing properties near the critical point. Tabulating the properties avoids real-time calculation with complex equations for each cell.
The first version is available at https://github.com/ldenies/tabulatedProperties Note that the code is not very tidy and still contains some remnants of the perfectGas files that were used as a basis.
One question I have is how to load the table files from the case directory. I am currently loading them directly from my home directory which is neither desirable nor flexible; see beneath.
cpTable_ ("/home/luka/cp")
I would prefer to put the files in the constant directory and load them from there. I tried to program the following but this failed to compile because runTime was not defined in this scope.
cpTable_ (runTime.path()/"constant/cp")
Any thoughts on how to implement this?
Hi, Luka,
I have problems to generated the table structure files by using your Python script "thermoClass.py" and "smartGenerator.py". When I input "python thermoClass.py", the error information is as follow:
Traceback (most recent call last):
File "thermoClass.py", line 10, in <module>
from scipy.interpolate import interp1d
ImportError: No module named scipy.interpolate
Besides, I input "python smartGenerator.py", the error information is:
File "smartGenerator.py", line 16, in <module>
from thermoClass import thermo
File "/home/jeo-1/OpenFOAM/tabulatedProperties-master/tableGenerator/thermoClass.py", line 10, in <module>
The system is Ubuntu 14.04 and the python is "Python 2.7.6 (default, Nov 13 2018, 12:45:42) [GCC 4.8.4] on linux2".
I don't know how to deal with these problems. Please let me know if you know where I'm wrong! Thanks
Old   August 3, 2021, 06:27
Joao Coelho
jcoelho5 is on a distinguished road
Originally Posted by FluidDynamicsTheory View Post
Hi Luka,
Were you able to install the application in the OpenFOAM8. Was your only problem using the .py scripts?
I am having some troubles installing this in general. Anyone has some kind of simple instructions to do after downloading the code from Denis git-repo?
jcoelho5 is offline   Reply With Quote
equation of state, supercritical, tabulated, thermo
how to incorporate the temperature of fluid in pressure based cavitation model arindamsantra7 Main CFD Forum 0 September 23, 2014 10:46
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Modeling interface of fluid and porous, not with default setting ftab CFX 27 May 20, 2014 06:58
Question about CFX transitional fluid model Anna Tian CFX 1 January 28, 2013 20:14
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
