When particles rebound, what's the wall velocity? |
July 7, 2015, 21:35 |
xue
Rep Power: 11 |
Hello everyone,
I want to use DPMFoam and I investigated how a particle rebounds when encountering walls: U = U(particle) - U(wall) U -=(1+e)*(U&nw) However, I 'm confused about U(wall), U(wall) is from KinematicCloud.C, line 726, the comment there says "Only wall patches may have a non-zero wall velocity from the velocity field when the mesh is not moving." Accoring to the codes, if a patch is wall, U(wall) shall be U.ari[boundary], else U(wall) shall be zero. What does the comment mean?If the bottom of a pipe is wall, U(wall) shall be the velocity of fluid at bottom, though the bottom is not moving!I'm quite confused. |
July 13, 2015, 20:09 |
#2 | |
Kyle Mooney
I think this would be the case if you have a partial or full slip condition at a wall.
in k-epsilon wall function approach high Re turbulence models: question of velocity | romant | OpenFOAM Programming & Development | 6 | May 26, 2016 09:14 |
Particles are not hitting the wall | CedricVH | OpenFOAM Bugs | 23 | May 19, 2016 20:29 |
Finely dispersed particles in predetermined velocity field | BrainDebugger | STAR-CCM+ | 1 | May 14, 2014 06:32 |
particle tracking | sakurabogoda | CFX | 7 | December 4, 2013 23:12 |
How to define a parabolic velocity inlet of particles with UDF | zumaqiong | FLUENT | 2 | February 22, 2010 09:46 |
