Writing data to a file
Like Tree4Likes
  • 3 Post By hk318i
  • 1 Post By hk318i
Old   July 14, 2015, 02:11
Default Writing data to a file
kcn
kcn is on a distinguished road
I modified a solver to calculate a scalar coefficient which I need to compare with some experimental data.
This coefficient is not a scalar field, a simple scalar for each time value.
My problem is how shall I write this scalar to some text file along with time value? Some thing like:
(time scalar value)
(0 0 )
(0.1 0.125 )
(0.2 0.137 )
etc?
Or some alternative form is also fine. All I need to write is coefficient and time.
Can some one please help?
kcn is offline   Reply With Quote
Old   July 14, 2015, 10:05
Hassan Kassem
hk318i is on a distinguished road
I believe this question was answered before in this forum, here is a short answer
#include "OFstream.H"
    fileName name = ("yorFileName");
    OFstream OS(name);
    if (Pstream::master())
        if(OS.opened())
             OS << runTime.value() << tab << scalarValue << endl;
You can use space instead of tab and could add "(" and ")". It works like Info stream.
hk318i is offline   Reply With Quote
Old   July 15, 2015, 04:32
Mehdi Asghari
Asghari_M is on a distinguished road
Hello Hassan and Kcn ;
Should we use OFstream or IOdictionary?
In which part of OpenFoam code, users should add above your code lines?
Thanks for any answer.
Asghari_M is offline   Reply With Quote
Old   July 15, 2015, 05:19
Hassan Kassem
It depends on your needs. for example in OF forces library OFstreams are used because the library requires writing every time step. IOdictionary are useful if in case of OF writing fields or object. It is generally writes when time.write() reached the writing criteria.
You use this code anywhere based on your code layout and the limitations of OFstreams.
Generally for solvers, as per the original question, you can declare the OFstream before the time loop then use the OFstream object anywhere in your code in the same way as using Info or cout.
Old   July 18, 2015, 04:53
Mehdi Asghari
Hello Hassan;
Really, I have a problem which I want to know if I have to use OFstream or IOdictionary.
Suppose, There is an inlet x-axis velocity as boundary condition in my problem.
I'm going to save the flow field for four different inlet velocity values.
These four inlet velocities have been specified according to the following expression in a vector:
A={1, 2, 3.5, 4.2}.
Therefore, I defined boundary condition as follows:
inlet
type codedFixedValue;
value $internalField;
redirectType ramp;
code
# How to read A[i] from main C++ program ( stated at next code)? Should I use IOdictionary or OFstream?
(*this)==vector(A(i),0,0);
Now, what I need is running OF into a loop (Main program) as follows:
#start of Main program
vector<double> A(4);
A[0]=1;A[1]=2;A[2]=3.5;A[3]=4.2;
for (int i = 0; i < 4; ++i)
# How to run OF program into a loop with A[i] in this line?
# How to save steady state flow in the separated folder for every inlet velocity in this line?
#end of main program
I asked my questions in above command lines with red color.
Thanks for any kind attention &answer.
Old   July 18, 2015, 07:23
Hassan Kassem
Hello Mehdi,
I haven't the full answer for your questions but I would like to highlight few points;
  • Regarding the first point, I have limited experience with codeStream in this area but based on my understanding you cannot access a variable A from the solver scope in BC scope unless it could be accessed through the object registry using look-up.
  • Transfer information between different parts of your code isn't a good programming practice because it isn't efficient (slower than reading from memory).
  • Your problem isn't entirely clear to me, is A vector constant or variable? If constant, you can define A in U file, then use dict.lookup("A") inside your codeStream as scalarField
    A (1, 2, 3.5, 4.2);
  • If A is variable depends on flow filed parameters and time, I would recommend implementing new BC based on fixed value BC OR you can change the BC value from your solver (less recommend).
  • In OF language vector is a fixed length list of size three. It is a vector in three-dimensional space. In your main program you are using the std::vector<double> which is in OF language scalarField of size four. It is preferable to use OF library over the standard c++ one.
  • For writing A in different files and folders, you have to declare OFstream for each inlet with different fileName then write inside the loop. Pleas note it is a minimal example and it will write over the existing files, therefore you have to rename it before restarting.
    #include "OSspecific.H" // for mkDir
        label size = 4;
        List<fileName> names(size); // files names and paths list
        PtrList<OFstream> os(size); // pointer list to OFstream
        // initialization
        forAll(names, i)
            names[i] = ("folder_"+ Foam::name(i))/("file_"+Foam::name(i)+".dat");
            os.set(i, new OFstream(names[i]));
            mkDir(names[i].path()); // create folders
    scalarField A(size,0.0); // size four with zero elements
    //loop which is equal to standard for-loop in c++
    forAll(A, i)
        A[i] = i; //assign as value for each element
          // check files and the master processor for writing
          if(os[i].opened() && Pstream::master())
              os[i] << A[i] << endl;
          else
             // stop the code if the files haven't opened
              FatalError
                  << "files aren't open" << nl
                  << exit(FatalError);
I hope that my comments will be useful for your case and kindly notice that these are just general recommendations you shouldn't consider them as the only solution or a black and white guidelines. For example you will find that sometimes is essential to use the standard for-loop and OF source code has plenty of such cases.
ucceyrekkokorec likes this.
Old   July 19, 2015, 05:29
Mehdi Asghari
Hello Hassan,
First of all, I should describe that in my case , every member of vector(A) is corresponding with a inlet velocity that is in X-axis direction (Ux).
Suppose, I need to gain flow field for t=10 s.
I don't need transient results up to 10s and I'd like to compare flow fields corresponding every inlet velocity with together in final time (t=10s).
There are two ways for this object explained as follows:
1-Running OF by run command in Ubuntu for every Ux with considering fix value for inlet boundary condition.
Then comparing results and plotting graphs for every Ux (Vector A).
2- Altogether, Writing a code to run OF within a loop calling OF 2.3.1 and calling every Ux=A(i) and saving 10s results for every Ux in a separated folder.
In this case, calling OF within loop is an important issue. In my belief, this way is faster than first option.
I selected second option. Obviously, for option 2, Wmake command have to be executed after code writing until code be executable.
How can I do this case ? What are general guidelines for wring a code according to the way (option)2 ?
Thanks,
Old   July 19, 2015, 05:46
Hassan Kassem
As I understand, you want to run you solver with four different inlet conditions for Ux and stop and save the results after 10s. Additionally you want to run these for cases automatically.
I would suggest in that case to write bash script (like Allrun in OF) to loop over the different cases and you can change the BC using sed command. Also you can have a look on pyFoam maybe it could do the job for you.
Old   July 19, 2015, 12:21
Mehdi Asghari
Yes, it is precisely the case I should do.
I don't know great things about bash scripting.
For example, how can I transfer vector/matrices values between inlet boundary & basch script?
For example, I defined inlet boundary in blockMeshdict as follows:
inlet
redirectType ramp;
code
# How to read A[i] from main bash scripting code presented as follows?
And, bash script Allrun code as follows:
# Is this expression correct here?---> A={1, 2, 3.5, 4.2}
# How create folders here for every Ux?
for i =1 to 4
do
   runApplication $(getApplication)
done
How should I write vector A with four Ux components in bash script and then transfer it to inlet boundary in blockMesh?
Also, I tried to use PyFoam. However, after installing PyFoam, I had some troubles with a simple tutorial that I post it at following post:
http://www.cfd-online.com/Forums/ope...-problems.html
Again, I asked my questions with red color at above codes.
Many thanks for your attentions.
Old   July 19, 2015, 12:46
Hassan Kassem
I really cannot help with pyFoam because I don't use it but I read many times on this forum how it could help solving such problems. I think even basic python script could solve your problem.
For bash script, it should be straight forward to create and copy folder because it works exactly like working from the terminal. Your for loop syntax is right, for more options see;
http://tldp.org/HOWTO/Bash-Prog-Intro-HOWTO-7.html
Also, you will need to modify the velocity BC from your bash script which could be done using sed see;
http://stackoverflow.com/questions/5...ork-it-empties
I hope these hints could be useful because I have limited experience with bash scripting in general.
Old   July 20, 2015, 16:41
Mehdi Asghari
Hello Hassan,
Thank you very much for your attentions & advises during this discussion.
Although, I have many problems with reading and writing files/data/vectors into OF and vise versa operation yet that I will probably have to post them in next treads and I welcome you to take part in the my next discussion soon.
Sincerely.
M.Asghari
Old   April 17, 2016, 10:02
Aaron
Aaron_L is on a distinguished road
    OFstream OS(name);
        if(OS.opened())
Hi, Hassan,
I use OF2.3.1 version, why I use this expression or only use OFstream.H head file
show this errors? can you provide some suggestion?
/usr/include/c++/4.8/bits/codecvt.h: In function ‘int main(int, char**)’:
/usr/include/c++/4.8/bits/codecvt.h:41:15: error: expected ‘=’ before ‘__attribute__’
namespace std _GLIBCXX_VISIBILITY(default)
/usr/include/c++/4.8/bits/codecvt.h:41:15: error: expected identifier before ‘__attribute__’
/usr/include/c++/4.8/bits/codecvt.h:41:15: error: expected ‘;’ before ‘__attribute__’
/usr/include/c++/4.8/bits/codecvt.h:41:15: error: expected primary-expression before ‘__attribute__’
Best Reards,
Aaron
Aaron_L is offline   Reply With Quote
Old   April 17, 2016, 10:48
Hassan Kassem
Hello Aaron,
I don't fully understand your question. Could you please include the code which gives this error?
I'm sure that this problem isn't related to OF version because I used this class many times under diffrent versions.
Bw,
Hassan Kassem
Originally Posted by Aaron_L View Post
Hi, Hassan,
Best Reards,
Aaron
Old   March 21, 2021, 21:50
Post How can I avoid overwritting its old time value ?
  #14
王子阳
wangziyang is on a distinguished road
    OFstream OS(name);
        if(OS.opened())
The code works well in my own class, but in the "yourFileName" file, the output scalar over writes on its old time value.
How can i solve this problem?
best wishes
ziyang
wangziyang is offline   Reply With Quote
Old   November 19, 2022, 14:26
Shah Akib Sarwar
Shah Akib Sarwar is on a distinguished road
best wishes
ziyang
Did you ever solve this problem? I am facing the same issue.
Shah Akib Sarwar is offline   Reply With Quote
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
