chtMutiRegionSimpleFOam diverges when evaluating fluid region |
October 15, 2015, 20:51 |
Franco
Rep Power: 10 |
Hi foamers
I"m having troubles in learning how to use the solver chtMutiRegionSimpleFOam. I've been able to successfully simulate the heat transfer in a geometry formed by several solid regions with different thermo-physical properties. Now I would like to replace one of these solid region with a fluid (air). In this way, the fluid would be surrounded by other solids at high temperature and natural convection should occur. I've made the necessary changes in the changeDictionaryDict, fvSchemes, fvSolution files and in the files located in constant/fluidregion (thermophysicalproperties, g, turbolenceProperties...). Nonetheless, it seems that I'm missing something. Effectively, once I run the simulation, I get the following error Code:
--> FOAM FATAL ERROR: Maximum number of iterations exceeded From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const in file /home/openfoam/OpenFOAM/OpenFOAM-2.4.0/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy>::THs(double, double, double) const at ??:? #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:? #4 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? at ??:? Aborted (core dumped) Thank you very much!!! Franco |
June 21, 2016, 04:42 |
Vishesh
Rep Power: 9 |
I am facing the exact same problem. Please help!
chtmultiregionsimplefoam, convergance, divergence |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
Boundary conditions for two connected fluid region. | hut | OpenFOAM Running, Solving & CFD | 3 | June 20, 2019 16:45 |
heat conducting solid within a fluid medium? | sieginc. | STAR-CCM+ | 1 | February 19, 2012 11:48 |
Diffusion from fluid region into porous tissue. | Lindz | FLUENT | 0 | August 3, 2007 07:34 |
