Change boundary conditions on fly by string definition
Old   December 15, 2015, 11:03
Default Change boundary conditions on fly by string definition
Algis Dziugys
Algis is on a distinguished road
Initial file of the pressure contains inlet boundary condition defined in boundaryField section, as for example "Inlet{type fixedValue; value uniform 0;}". Code reads pressure field from this file and further uses for simulation.
But, during the simulation, pressure inlet must be change from initially defined to another type defined by string, as for example "Inlet{type zeroGradient;}" (or other type of boundary condition defined by string and unknown in advance).
Is it possible to program such trick? Something like that, as for example:
p.redefineBoundaryField("Inlet", "Inlet{type zeroGradient;}");
Thank you very much in advance,
Algis is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Problems when change the boundary conditions in rhoSimplicFoam tutorial example SylvainWang OpenFOAM 1 December 17, 2014 15:43
ribbed channel / simpleFoam / boundary conditions beeo OpenFOAM Pre-Processing 20 July 17, 2013 08:39
