Electric Potential Method for MHD Duct Flow
Old   December 7, 2015, 16:40
Default Electric Potential Method for MHD Duct Flow
Jun
mykkujinu2201 is on a distinguished road
Hello.
I'm currently working on electric potential method to solve MHD Duct Flow
Because it uses electric potential method, I have to compile new solver.
I tried to modified simplefoam to solve MHD and I made it.
However, it does not converge at high Hartman lminar flow.
Thas is why I decided to find some code on the internet and I found one.
I copied and modified but it did not work. There was errors.
The code is as below
#include "fvCFD.H"
#include "pisoControl.H"
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    pisoControl piso(mesh);
    pisoControl bpiso(mesh, "BPISO");
    #include "createFields.H"
    #include "initContinuityErrs.H"
    Info<< nl << "Starting time loop" << endl;
    while (runTime.loop())
    Info<< "Time = " << runTime.timeName() << nl << endl;
        #include "CourantNo.H"
        volVectorField UcrosB= U ^ B;
        volVectorField j=-sigma*fvc::grad(PotE) + sigma*UcrosB;
        volVectorField jcrosB = j ^ B;
            fvVectorMatrix UEqn
                fvm::ddt(U)
              + fvm::div(phi, U)
          - (jcrosB/rho)
          - fvm::laplacian(nu,U)
            if (piso.momentumPredictor())
                solve(UEqn == -fvc::grad(p));
            // --- PISO loop
            while (piso.correct())
                volScalarField rAU(1.0/UEqn.A());
                surfaceScalarField rAUf("rAUf", fvc::interpolate(rAU));
                volVectorField HbyA("HbyA", U);
                HbyA = rAU*UEqn.H();
                surfaceScalarField phiHbyA
                    "phiHbyA",
                    (fvc::interpolate(HbyA) & mesh.Sf())
                  + rAUf*fvc::ddtCorr(U, phi)
                while (piso.correctNonOrthogonal())
                    fvScalarMatrix pEqn
                        fvm::laplacian(rAUf, p) == fvc::div(phiHbyA)
                    pEqn.setReference(pRefCell, pRefValue);
                    pEqn.solve(mesh.solver(p.select(piso.finalInnerIter())));
                    if (piso.finalNonOrthogonalIter())
                        phi = phiHbyA - pEqn.flux();
                #include "continuityErrs.H"
                U = HbyA - rAU*fvc::grad(p);
                U.correctBoundaryConditions();
        // --- B-PISO loop
        while (bpiso.correct())
            fvVectorMatrix BEqn
                fvm::laplacian(PotE) == fvc::div(UcrosB)
            BEqn.solve();
            #include "magneticFieldErr.H"
        runTime.write();
    Info<< "End\n" << endl;
    return 0;
The error is as below.
Making dependency list for source file EpisoFoam.C
g++  -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall  -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter  -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100  -I/opt/openfoam30/src/finiteVolume/lnInclude  -I/opt/openfoam30/src/meshTools/lnInclude -IlnInclude -I.  -I/opt/openfoam30/src/OpenFOAM/lnInclude  -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude   -fPIC -c EpisoFoam.C  -o Make/linux64GccDPInt32Opt/EpisoFoam.o
EpisoFoam.C: In function ‘int main(int, char**)’:
EpisoFoam.C:148:13:  error: no matching function for call to  ‘Foam::fvMatrix<Foam::Vector<double>  >::fvMatrix(Foam::tmp<Foam::fvMatrix<double> >)’
EpisoFoam.C:148:13: note: candidates are:
In file included from /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.H:1058:0,
                 from /opt/openfoam30/src/finiteVolume/lnInclude/ddtScheme.C:29,
                 from /opt/openfoam30/src/finiteVolume/lnInclude/ddtScheme.H:337,
                 from /opt/openfoam30/src/finiteVolume/lnInclude/fvcDdt.C:28,
                 from /opt/openfoam30/src/finiteVolume/lnInclude/fvcDdt.H:199,
                 from /opt/openfoam30/src/finiteVolume/lnInclude/fvc.H:44,
                 from /opt/openfoam30/src/finiteVolume/lnInclude/fvCFD.H:8,
                 from EpisoFoam.C:51:
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:418:1:  note: Foam::fvMatrix<Type>::fvMatrix(const  Foam::GeometricField<Type, Foam::fvPatchField,  Foam::volMesh>&, Foam::Istream&) [with Type =  Foam::Vector<double>]
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:418:1: note:   candidate expects 2 arguments, 1 provided
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:361:1:  note: Foam::fvMatrix<Type>::fvMatrix(const  Foam::tmp<Foam::fvMatrix<Type> >&) [with Type =  Foam::Vector<double>]
 Foam::fvMatrix<Type>::fvMatrix(const tmp<fvMatrix<Type> >& tfvm)
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:361:1:  note:   no known conversion for argument 1 from  ‘Foam::tmp<Foam::fvMatrix<double> >’ to ‘const  Foam::tmp<Foam::fvMatrix<Foam::Vector<double> >  >&’
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:330:1:  note: Foam::fvMatrix<Type>::fvMatrix(const  Foam::fvMatrix<Type>&) [with Type =  Foam::Vector<double>]
 Foam::fvMatrix<Type>::fvMatrix(const fvMatrix<Type>& fvm)
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:330:1:  note:   no known conversion for argument 1 from  ‘Foam::tmp<Foam::fvMatrix<double> >’ to ‘const  Foam::fvMatrix<Foam::Vector<double> >&’
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:273:1:  note: Foam::fvMatrix<Type>::fvMatrix(const  Foam::GeometricField<Type, Foam::fvPatchField,  Foam::volMesh>&, const Foam::dimensionSet&) [with Type =  Foam::Vector<double>]
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:273:1: note:   candidate expects 2 arguments, 1 provided
make: *** [Make/linux64GccDPInt32Opt/EpisoFoam.o] 오류 1
root@ubuntu:~/OpenFOAM/mykkujinu2201-3.0.0/solver/EpisoFoam# wmake
Can you help me to solve this problem?
And also, I'm curious about OpenFoam syntax.
I'm quite sure that the syntax has changed at this version.
So, even though I got codes from the internet, it does not work.
What has changed in this version?
Where can I find it?
mykkujinu2201 is offline   Reply With Quote
compile, electric potential, mhd
Ansys 11.0 CFX - solving electric potentials and multiphase flow cfd_multiphyiscs CFX 2 March 10, 2010 13:43
Variable name for electric potential Vignamitra Main CFD Forum 0 July 10, 2009 04:34
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
3D Galerkin BEM for Potential Flow Adrin Gharakhani Main CFD Forum 1 May 27, 1999 10:08
