boundaryField access for derived quantities
Old   January 20, 2016, 06:48
Default boundaryField access for derived variables
abhiv is on a distinguished road
Hello OFoamers, I'm relatively new to OpenFOAM community. I'm facing an issue while defining boundary condition to one of the variables in a custom solver using openfoam.
In particular, I'm calculating Flux of a quantity, which is function of two other independent variables. But I need to provide boundary conditions for the flux but not the independent variables. Independent variables may have "calculated" BC.
Here is a part of createFields.H, showing one possible situation. "Flux" requires a boundary condition to solve the physics correctly, but the solver is not reading boundaryField while running. I think that it occurs because I'm not providing 'mesh' condition instead of equation for "Flux" in IOobject. The "Flux" is also being used in another PDE solution.
    volVectorField Flux
        IOobject
            "Flux",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        N*U
Is there a solution already exists in OpenFOAM for this problem? Please advice me if I am interpreting the openfoam guidelines incorrectly for createFields.H. How to approach if I have to come up with an utility to perform this job?
Thanks in advance,
ABHI
abhiv is offline   Reply With Quote
Old   May 31, 2017, 19:29
Sugajen
Sugajen is on a distinguished road
Hi Abhi,
I have a similar situation. Did you figure out a way?
Thanks
Sugajen is offline   Reply With Quote
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 15:13
Access boundaryMesh / boundaryField on cellZone Nucleophobe OpenFOAM Programming & Development 17 November 13, 2019 12:27
Reading Additional Data Quantities from Fluent into Tecplot fremder Tecplot 9 December 16, 2016 15:35
UDF Data Access Macro Woo Meng Wai FLUENT 0 November 6, 2007 20:23
Access to the derivatives of quantities at cells Parsa Zamankhan FLUENT 0 September 18, 2007 19:30
