Access to neighbor faces on a boundary
Like Tree5Likes
  • 1 Post By giack
  • 3 Post By marupio
  • 1 Post By tiam
Old   February 19, 2016, 09:36
Default Access to neighbor faces on a boundary
giack is on a distinguished road
Dear all,
I have a problem in the implementation of a smoothing filter that smooth a value averaging the neighbor ones.
The variable to smooth (let's call it sensitivity) is a volScalarField defined only along a wall surface. Therefore, the sensitivity is zero everywhere and different from zero on the wall faces.
I have access to the face values on the wall with sensitivity.boundaryField() but I'm not able to take the values of the neighbor faces on the wall. The typical way how to have access to neighbors is to use mesh.cellCells() and mesh.neighbor() but they are related to neighbor cells and neighbor internal faces respectively.
Someone knows how to have access to the neighbor faces on a boundary (the wall in my case)?
Thanks for any help
Giacomo
atulkjoy likes this.
giack is offline   Reply With Quote
Old   February 19, 2016, 10:36
David Gaden
marupio is on a distinguished road
sensitivity.boundaryField()[patchI] will give a fvScalarPatchField with all the values on it. Call patch() to get fvPatch, then call patch() again to get polyPatch. That has connectivity:
forAll(sensitivity.boundaryField(), i)
    fvScalarPatch& patchI(sensitivity.boundaryField()[patchI]);
    polyPatch& pp(patchI.patch().patch());
pp is now a polyPatch and has all the connectivity data. pp[faceIndex] gives a list of edges associated with that face. pp.edgeFaces[edgeIndex] gives a list of all faces associated with a given edge index. You may have to check to make sure the face you found is not an internal face. Then map back to the value.
I'm sure there's an easier way. Try looking for examples. PrimitivePatch::calcPointNormals creates a normal for each point on the face that is the average of the surrounding face normals. May be useful. (Mind you, this one doesn't account for parallel processing.)
Sorry for the ramble. Hope this helps ever so slightly.
Need more coffee this morning.
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   April 29, 2016, 06:15
Many thanks for the advice, I'll have a look on that.
For the moment I solved the problem in a more simple way. I perform a double interpolation:
- interpolation of the face values to obtain the values on the boundary points (faceToPointInterpolate).
- interpolation of the boundary values to obtain the values on the face centers (pointToFaceInterpolate).
The interpolation is a linear interpolation so essentially I average twice to get a smoother values on the face center. In this way the smoothing is more conservative than a simple average between the face center values.
However, I still want to try to develop the first idea so I will check more in detail your suggestions.
Old   January 29, 2019, 07:23
Timofey Mukha
tiam is on a distinguished road
A short note after working with a similar thing. Instead of pp[faceIndex], use pp.faceEdges()[faceIndex] to use local addressing, compatible with pp.edgeFaces()[edgeIndex].
tiam is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Access to the velocity at boundary cells mathslw OpenFOAM 14 January 9, 2018 23:31
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 08:16
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
