BasicTurbulenceModel class declaration in OpenFOAM 6 |
April 12, 2019, 15:34 |
Rodrigo Petrone dos Anjos
Rep Power: 12 |
I was trying to understand turbulence models implementation in OpenFOAM 6. Nevertheless, in linearViscousStress. H, it is used a parent class called BasicTurbulenceModel, which is the class template parameter too. I have not been able to find BasicTurbulenceModel declaration and definition. Does someone know where it is in OpenFOAM? Or is it a declaration way that i am not familarizied with? Codes: linearViscousStress.H: Code:
#ifndef linearViscousStress_H #define linearViscousStress_H // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // namespace Foam { /*---------------------------------------------------------------------------*\ Class linearViscousStress Declaration \*---------------------------------------------------------------------------*/ template<class BasicTurbulenceModel> class linearViscousStress : public BasicTurbulenceModel { public: typedef typename BasicTurbulenceModel::alphaField alphaField; typedef typename BasicTurbulenceModel::rhoField rhoField; typedef typename BasicTurbulenceModel::transportModel transportModel; // Constructors //- Construct from components linearViscousStress ( const word& modelName, const alphaField& alpha, const rhoField& rho, const volVectorField& U, const surfaceScalarField& alphaRhoPhi, const surfaceScalarField& phi, const transportModel& transport, const word& propertiesName ); //- Destructor virtual ~linearViscousStress() {} // Member Functions //- Re-read model coefficients if they have changed virtual bool read() = 0; //- Return the effective stress tensor virtual tmp<volSymmTensorField> devRhoReff() const; //- Return the source term for the momentum equation virtual tmp<fvVectorMatrix> divDevRhoReff(volVectorField& U) const; //- Return the source term for the momentum equation virtual tmp<fvVectorMatrix> divDevRhoReff ( const volScalarField& rho, volVectorField& U ) const; //- Solve the turbulence equations and correct the turbulence viscosity virtual void correct() = 0; }; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // } // End namespace Foam // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #ifdef NoRepository #include "linearViscousStress.C" #endif // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #endif Code:
#include "linearViscousStress.H" #include "fvc.H" #include "fvm.H" // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // template<class BasicTurbulenceModel> Foam::linearViscousStress<BasicTurbulenceModel>::linearViscousStress ( const word& modelName, const alphaField& alpha, const rhoField& rho, const volVectorField& U, const surfaceScalarField& alphaRhoPhi, const surfaceScalarField& phi, const transportModel& transport, const word& propertiesName ) : BasicTurbulenceModel ( modelName, alpha, rho, U, alphaRhoPhi, phi, transport, propertiesName ) {} // * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * // template<class BasicTurbulenceModel> bool Foam::linearViscousStress<BasicTurbulenceModel>::read() { return BasicTurbulenceModel::read(); } template<class BasicTurbulenceModel> Foam::tmp<Foam::volSymmTensorField> Foam::linearViscousStress<BasicTurbulenceModel>::devRhoReff() const { return tmp<volSymmTensorField> ( new volSymmTensorField ( IOobject ( IOobject::groupName("devRhoReff", this->alphaRhoPhi_.group()), this->runTime_.timeName(), this->mesh_, IOobject::NO_READ, IOobject::NO_WRITE ), (-(this->alpha_*this->rho_*this->nuEff())) *dev(twoSymm(fvc::grad(this->U_))) ) ); } template<class BasicTurbulenceModel> Foam::tmp<Foam::fvVectorMatrix> Foam::linearViscousStress<BasicTurbulenceModel>::divDevRhoReff ( volVectorField& U ) const { return ( - fvc::div((this->alpha_*this->rho_*this->nuEff())*dev2(T(fvc::grad(U)))) - fvm::laplacian(this->alpha_*this->rho_*this->nuEff(), U) ); } template<class BasicTurbulenceModel> Foam::tmp<Foam::fvVectorMatrix> Foam::linearViscousStress<BasicTurbulenceModel>::divDevRhoReff ( const volScalarField& rho, volVectorField& U ) const { return ( - fvc::div((this->alpha_*rho*this->nuEff())*dev2(T(fvc::grad(U)))) - fvm::laplacian(this->alpha_*rho*this->nuEff(), U) ); } template<class BasicTurbulenceModel> void Foam::linearViscousStress<BasicTurbulenceModel>::correct() { BasicTurbulenceModel::correct(); } // ************************************************************************* // Last edited by wyldckat; August 5, 2019 at 19:21. Reason: Added [CODE][/CODE] markers |
April 15, 2019, 04:28 |
Gerhard Holzinger
Rep Power: 28 |
There is no class named BasicTurbulenceModel, it is a template parameter from which some classes are also derived from. In order to make sense of this, get familiar with the C++ concepts of object orientation, inheritace and templates.
In OpenFOAM's hierarchy of turbulence models, there are two basic categories of turbulence models: incompressible and compressible ones. Thus, OpenFOAM derives from the base-class of all turbulence models turbulenceModel two classes: incompressibleTurbulenceModel and compressibleTurbulenceModel. These two classes are then used as template parameter to build the model-trees for incompressible and compressible turbulence models. Unfortunately, the organisation of the turbulence model classes is not easy to get to understand, and it is also not easy to explain, at least for me. However, it is a brilliant way to avoid the code duplication that was there before. Download the sources of any OpenFOAM version prior to 3.0, and expore the content of $FOAM_SRC/turbulenceModels. Easier to grasp, yet lots of duplicated code. |
April 15, 2019, 05:16 |
Yan Zhang
Rep Power: 12 |
You can find the compressible part here: https://openfoam.top/en/turb/
Sorry for that the language is Chinese. But the UML is clear:
https://openfoam.top Last edited by zhangyan; April 19, 2019 at 06:23. |
April 15, 2019, 08:27 |
Rep Power: 12 |
Hi Gerhard,
I am familiar with many of this C++ concepts of object orientation, inheritace and templates, what i have not understand it was the template parameter used as a parent class, i haven't seen this before. But i think i was able to understand now. At the same time, BasicTurbulenceModel is a parameter, this parameter becomes the parent class of linearViscousStress class. OpenFOAM version prior to 3.0 i understand the turbulence models class, because i had to implement turbulence models in OpenFOAM 2.3 to my master thesis. Thank you for the answer. Best regards, Rodrigo Petrone |
basicturbulencemodel, openfoam6, turbulencemodels |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 14, 2016 10:19 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
Possible bug in OpenFoam Interpolation class | MMC15 | OpenFOAM Bugs | 2 | March 23, 2014 12:55 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
