How to accelerate findCell?
Like Tree3Likes
  • 2 Post By fst-student
  • 1 Post By fst-student
Old   September 4, 2015, 06:01
Default How to accelerate findCell?
fst-student is on a distinguished road
I have the coordinates of a large amount of points and have to find the cooresponding points inside the mesh. For this I'm using the findCell command. I expect that this search has the longest duration in my code. Is there a possibilty to accelerate this command?
Thank you very much
Jens
fst-student is offline   Reply With Quote
Old   September 6, 2015, 09:06
Bruno Blais
blais.bruno is on a distinguished road
I think it depends on the search method you use.
There is a way to use a tree-based search which is significantly faster than the generic find cell. This is what is used within the CFDEM framework and its relatively fast.
Thank you very much
Jens
blais.bruno is offline   Reply With Quote
Old   September 6, 2015, 11:23
Thanks for the answer. Do you have some more information about it or a hint, webside or documentation where I can read more about it?
Thank you
Old   September 6, 2015, 11:33
Bruno Blais
Sure,
the class is meshSearch
Then if you intiate your meshSearch engine using something like:
meshSearch searchEngine_;
searchEngine_(particleCloud_.mesh(),polyMesh::FACE_PLANES);
You can search using the .findCell() routine of meshSearch.
Thank you
Old   September 7, 2015, 10:25
Thank you very much. It is not completly clear for me.
I have to define the meshSearch engine right?
I don't know which parameter I have to set for the definition of the search engine.
Obviously I have to change the variable particleCloud_.mesh() but I don't know how it is called in my chase. What is this variable exactly and how can I find it? Can I use the second part (polyMesh::FACE_PLANES) or do I have to change it to?
If I have defined it I can use the mesh.findCell[cellnumber] command to find the cell and openfoam uses the tree search.
I have found the following command:
findCell (const point &location, const label seedCellI=-1, const bool useTreeSearch=true)
. Do I have to set the variables in brakets to use the tree search?
Sorry I'm new to openfoam.
Old   September 8, 2015, 12:17
Ok, I have tried something but I don't get it work.
Here is what I tried:
First of all I copied the meshSearch.H and used the #include command to make it accessable in my code.
Edit:
I integrated this code
meshSearch ms(mesh);
label cellNumber=ms.findCell(Point,-1,true)
EDIT2: The code is runnig and is about 8 times faster than the conventional findCell.
Thank you very much!
kk415 and anhkenyt like this.
Old   September 25, 2015, 06:57
I have tested the perfomance of the findCell using several parameters.
The fastest way was this command:
meshSearch ms(mesh); label cellNumber=ms.findCell(Point,0,true)
The zero disables the seeding which slows the search down. Using this configuration the search is very fast.
The speed of search can also be improved by using the findNearestCell command. It is used in the same way:
meshSearch ms(mesh); label cellNumber=ms.findNearestCell(Point,0,true)
kk415 likes this.
Old   November 12, 2015, 13:17
Pete Bachant
pbachant is on a distinguished road
Have you tested this in parallel? I am profiling some code and it seems findCell and reduce are gobbling up lots of CPU when run in parallel.
Home | Twitter | GitHub
pbachant is offline   Reply With Quote
Old   November 12, 2015, 17:00
Pete Bachant
I just tried this out and got a ~20X speedup on a case that should not even be parallel (20k cells). The speed in serial using meshSearch::findNearestCell(point, 0, true) is about the same as polyMesh::findCell.
Old   July 20, 2016, 02:30
Flo
FlowingTech is on a distinguished road
Could anybody explain the differences between the two available options of the meshSearch class:
and
polyMesh::FACE_DIAGTETS
Furthermore, we discovered that implementations of the meshSearch::findCell() algorithm differ between ESI-OpenFOAM and foam-extend-3.2. Could anybody comment on this and explain which algorithm is used in foam-extend-3.2 ?
Cheeers.
FlowingTech is offline   Reply With Quote
Old   July 20, 2016, 08:24
Bruno Blais
The two should be different search options. The first one I guess uses the face positions, the other one might decompose cells into tetahedron to search? I am not sure?
I cannot comment on the foam-extend vs ESI-OpenFOAM. Honestly, it is too hard to track the différences between these codes...
and
Cheeers.
accelerate the convergence entropie OpenFOAM Running, Solving & CFD 2 October 10, 2014 18:58
Is it possible to accelerate the ode solver of reactingFoam? pajofego OpenFOAM Running, Solving & CFD 2 August 10, 2014 05:38
Problems with accelerate flow. Underwater Vehicle AntonioG Main CFD Forum 0 March 18, 2014 04:36
Accelerate the assembling of 3D convection matrix Isabel Main CFD Forum 6 December 22, 2005 12:22
Accelerate convergence in coupled solver Balaji FLUENT 3 June 23, 2005 18:16
