Turbulence model implementation
Old   July 16, 2018, 05:11
Default Turbulence model implementation
Xavier Lamboley
tilasoldo is on a distinguished road
I have an implementation of a turbulence model named sstTransition, which works great. However, my code requires the whole TurbulenceModels folder to be copied in the user source folder, which does not seem efficient to me. I would like instead to have only my turbulence model, and use the installation implementation for the rest.
Given that, I can't manage to find the correct compilation options to achieve that ; I tried to include the main installation lnInclude folders, which results in "duplicate entries in runtime selection table TurbulenceModel".
I try to compile that under the latest OpenFOAM 6. My TurbulenceModels folder and the required library findroot are attached.
Thank you very much for your help,
X. Lamboley
tilasoldo is offline   Reply With Quote
Old   July 16, 2018, 05:28
Pablo Higuera
Phicau is on a distinguished road
Hi Xavier,
take a look at these materials and repository, you will find an example on how to compile a SST-derived model without copying the original folder:
https://sites.google.com/view/olaflo...ve-simulations
Best,
Pablo
Check out my new project: olaFlow --> The olaFlow Support Thread
Phicau is offline   Reply With Quote
Old   July 29, 2018, 15:09
Default Works perfectly
Xavier Lamboley
This works like a charm, thank you so much for your help!
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 20:21
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 19:42
SA Turbulence model implementation ganesh Main CFD Forum 0 March 6, 2006 12:23
k-w Turbulence model implementation suneesh Main CFD Forum 4 November 23, 2005 17:35
A reference on implementation of Spalart-Alam. Turbulence Model? Mohammad Kermani Main CFD Forum 2 December 26, 1999 02:56
