July 12, 2016, 06:21 |
kinematic cloud properties-Regd
GS
Rep Power: 10 |
Dear All,
I would like to understand what is the meaning of "rhoMin" & "rho0" in the kinematic Cloud properties file in Lagrangian solver of foam-extend3.2 I want to specify and vary the density of the particles that I inject. For this, where should I make changes. Please let me know if you are aware of this... Also, please let me know these: "minParticleMass" & "RosinRammlerPDF" Thank you. |
July 14, 2016, 03:44 |
Karelke Yu
Rep Power: 11 |
Hi, Gaurav.
Has your problem solved? Could you please post your answers here so that more foamers can benifit from you? Best, |
July 14, 2016, 07:25 |
GS
Rep Power: 10 |
July 14, 2016, 04:10 |
#4 | |
Ping Chang
Rep Power: 10 |
You may find the answer for how to inject vary density particles from this post. http://www.cfd-online.com/Forums/ope...aticcloud.html rhoMin means minimum density (kg/m3) I think it's for parcel. rho0 means particle density kg/m3 (constant) for single particle minParcelMass means minimum parcel mass kg And one parcel could include many particles. the parameter nParticle means the number of particles for each parcel. If you set it as 1. It will be DEM. Kind regards, Ping |
July 14, 2016, 07:22 |
#5 | |
GS
Rep Power: 10 |
Thank you for the reply. But, I do not want to inject particles of varying densities, at one time, in the flow. I would like to inject particles of uniform density once, later in the next set of simulations, I want to inject particles with different value of density but uniform for all the particles. In this regard, I want to understand the difference between 'rho' and 'rho0' mentioned in the kinematicCloudProperties file. Thanks |
July 14, 2016, 20:40 |
#6 | |
Ping Chang
Rep Power: 10 |
Which solver are you using? DPMFoam? I have checked the kinematicCloudProperties file in DPMFoam tutorial, I did not find the parameter rho. There are only rhoMin and rho0 and I have explained that in my last post. |
July 14, 2016, 23:56 |
GS
Rep Power: 10 |
Hi Peng,
I am using icoLagrangianFoam in the Lagrangian solver. There also it is mentioned rhoMin and rho0 only. I have mistakenly queried for rho. But, Is there a limit on the value of rho0. Because, if i am changing the default value(5000) to some less values, foam is giving errors(FLOATING POINT EXCEPTION). Also, for moderate values of rho0, the solution is running only upto a limited number of time steps than that is mentioned in the controlDict file. Could you please clarify this. Thank you. |
July 14, 2016, 23:59 |
#8 | |
Ping Chang
Rep Power: 10 |
Could you post your error information (for more details) and kinematicCloudProperites file as well? And I recommend you to use a latest version. Regards. Ping |
July 15, 2016, 00:45 |
GS
Rep Power: 10 |
Hi Ping,
The error messages are: With "rho0-500 and rhoMin-150" Time = 1.051 Courant Number mean: 0.156148 max: 535.037 velocity magnitude: 115.568 Evolving kinematicCloud --> Cloud: kinematicCloud Added 5 new parcels Cloud: kinematicCloud Total number of parcels added = 5255 Total mass introduced = 2.80267e-05 Current number of parcels = 4254 Current mass in system = 2.2688e-05 Cloud: kinematicCloud Total number of parcels added = 5255 Total mass introduced = 2.80267e-05 Current number of parcels = 4254 Current mass in system = 2.2688e-05 DILUPBiCG: Solving for Ux, Initial residual = 0.990552, Final residual = 2.55921e-06, No Iterations 32 DILUPBiCG: Solving for Uy, Initial residual = 0.919057, Final residual = 5.83568e-06, No Iterations 32 DILUPBiCG: Solving for Uz, Initial residual = 0.938345, Final residual = 7.10839e-06, No Iterations 32 DICPCG: Solving for p, Initial residual = 0.682208, Final residual = 9.11394e-07, No Iterations 114 time step continuity errors : sum local = 3.32876e-07, global = 3.1143e-10, cumulative = -1.93215e-08 DICPCG: Solving for p, Initial residual = 0.978959, Final residual = 9.99862e-07, No Iterations 106 time step continuity errors : sum local = 1.0204e-05, global = 1.89962e-07, cumulative = 1.7064e-07 ExecutionTime = 159.17 s ClockTime = 159 s Time = 1.052 Courant Number mean: 6.44676 max: 28233.3 velocity magnitude: 6098.39 Evolving kinematicCloud --> Cloud: kinematicCloud Added 5 new parcels Floating point exception With "rho0-150 and rhoMin-1.0e-15" Time = 0.002 Courant Number mean: 0.0249048 max: 5.03595 velocity magnitude: 1.42542 Evolving kinematicCloud --> Cloud: kinematicCloud Added 5 new parcels Cloud: kinematicCloud Total number of parcels added = 10 Total mass introduced = 5.33333e-08 Current number of parcels = 10 Current mass in system = 5.33333e-08 Cloud: kinematicCloud Total number of parcels added = 10 Total mass introduced = 5.33333e-08 Current number of parcels = 10 Current mass in system = 5.33333e-08 DILUPBiCG: Solving for Ux, Initial residual = 0.310019, Final residual = 9.42003e-06, No Iterations 8 DILUPBiCG: Solving for Uy, Initial residual = 0.356904, Final residual = 9.69334e-06, No Iterations 7 DILUPBiCG: Solving for Uz, Initial residual = 0.492843, Final residual = 3.53762e-06, No Iterations 9 DICPCG: Solving for p, Initial residual = 0.0327284, Final residual = 9.13131e-07, No Iterations 109 time step continuity errors : sum local = 8.23451e-08, global = 6.57272e-10, cumulative = 1.46996e-09 DICPCG: Solving for p, Initial residual = 0.136092, Final residual = 8.68997e-07, No Iterations 114 time step continuity errors : sum local = 8.66451e-09, global = 2.07729e-11, cumulative = 1.49073e-09 ExecutionTime = 0.47 s ClockTime = 1 s Time = 0.003 Courant Number mean: 0.0259055 max: 5.00462 velocity magnitude: 2.06054 Evolving kinematicCloud --> Cloud: kinematicCloud Added 5 new parcels Cloud: kinematicCloud Total number of parcels added = 15 Total mass introduced = 8e-08 Current number of parcels = 13 Current mass in system = 6.93333e-08 Cloud: kinematicCloud Total number of parcels added = 15 Total mass introduced = 8e-08 Current number of parcels = 13 Current mass in system = 6.93333e-08 Floating point exception The kinematic cloud properties file (foam-extend 3.2) is the following: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.2 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object kinematicCloud1Properties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // active yes; // Particle sub-models InjectionModel ConeInjection; DragModel SphereDrag; DispersionModel none; PatchInteractionModel StandardWallInteraction; PostProcessingModel PatchPostProcessing; // Parcel basis type parcelBasisType mass; constantProperties{ rhoMin rhoMin [ 1 -3 0 0 0 ] 1e-15; // Minimum particle mass minParticleMass minParticleMass [ 1 0 0 0 0] 1.0e-15; // Parcel thermo properties rho0 rho0 [ 1 -3 0 0 0] 5000; } // Coupling between particles and carrier phase via source terms coupled true; cellValueSourceCorrection on; // Integer used to identify different parcel types parcelTypeId 2; interpolationSchemes { rho cell; U cellPointFace; mu cell; } integrationSchemes { U Euler; } particleForces { gravity off; virtualMass off; pressureGradient off; } ConeInjectionCoeffs { // type patchInjection; // patchName in; SOI 0; parcelBasisType mass; duration 7.5; position (0 0.0024 0.0024); direction (1 0 0); parcelsPerSecond 5000; volumeFlowRate constant 0.01; Umag constant 5.0; thetaInner constant 0.0; thetaOuter constant 90.0; parcelPDF { pdfType RosinRammler; RosinRammlerPDF { minValue 50.0e-06; maxValue 100.0e-06; d (75.0e-06); n (0.5); } } // Total mass to inject massTotal massTotal [ 1 0 0 0 0] 2.0e-4; } StandardWallInteractionCoeffs { type rebound; } PatchPostProcessingCoeffs { maxStoredParcels 10000; patches ( in out1 out2 ); } // ************************************************** *********************** // Thank you |
July 15, 2016, 03:31 |
#10 | |
Ping Chang
Rep Power: 10 |
Besides, the solver you use is different with mine, I am using the OF version from www.openfoam.org. But I think this is not the reason for your problem. Good luck |
July 18, 2016, 00:36 |
#11 |
vidyadhar
Rep Power: 9 |
Thank you Ping.
Regards, Vidyadhar/thegauravonline (from new CFD Online account) |
August 8, 2023, 05:52 |
answer
#12 |
desimuser1
Rep Power: 3 |
rho0 = your value (rho at time zero)
rhoMin = if varied, what is the least value that it has to maintain |
kinematic cloud properties-Regd | thegauravonline | OpenFOAM Programming & Development | 0 | July 12, 2016 06:15 |
kinematic cloud properties-Regd | thegauravonline | OpenFOAM Running, Solving & CFD | 0 | July 12, 2016 02:37 |
Conceptual misunderstanding of Kinematic Cloud class | dradenkovic | OpenFOAM Running, Solving & CFD | 0 | May 31, 2016 05:26 |
Kinematic cloud properies the meainig of the terms | manuc | OpenFOAM Programming & Development | 0 | February 23, 2016 07:29 |
problem with solving lagrange reaction cloud | Polli | OpenFOAM Running, Solving & CFD | 0 | April 30, 2014 07:53 |
