Two velocity files generated in each time step U and U_0..Why?
Old   July 29, 2016, 02:29
Default Two velocity files generated in each time step U and U_0..Why?
Manu Chakkingal
manuc is on a distinguished road
Hello all
I am using buoyantboussinesqPimpleFoam.
While running it without any modification in each time directory I have 1 U and 1T file
But after adding some probes at 4 points (always active) and field average (not active most time) in control dict there are
1 U 1U_0 1T and 1T_0 file generated. From manual comaprison I find U and U_0 to be the same and just occupying 2*space.
Is it any issue , or is there any reason for generation of these extra files in each time directory.
Hope the changes I made in controldict (no other changes made) is the probable reason for the generation of files:
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
libs (
"libOpenFOAM.so"
"libsimpleSwakFunctionObjects.so"
"libswakFunctionObjects.so"
"libgroovyBC.so"
application DNSbuoyantBoussinesqPimpleFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 20060;
deltaT .02;
writeControl timeStep;
writeInterval 10;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
adjustTimeStep yes;
maxCo 0.4;
functions
fieldAverage1
type fieldAverage;
functionObjectLibs ("libfieldFunctionObjects.so");
enabled true;
timeStart 20020;
timeEnd 20060;
outputControl timeStep;
writeInterval 10;
fields
U
mean on;
prime2Mean on;
base time;
p
mean on;
prime2Mean on;
base time;
NusseltNumber_hot
type patchExpression;
outputInterval 1;
patches (
w_l
verbose true;
variables (
"Tsat=301;"
"ln2D=3.065;" /*length(.08)/k(.0261) */
expression "ln2D*snGrad(T)/(T-Tsat)";
accumulations (
average
NusseltNumber_cold
outputInterval 1;
patches (
w_r
verbose true;
variables (
"Tsat=301;"
"k2D2=3.065;"
expression "-1*k2D2*snGrad(T)/(T-Tsat)";
accumulations (
average
probes1
// Type of functionObject
type probes;
outputInterval 1;
// Where to load it from (if not already in solver)
functionObjectLibs ("libsampling.so");
// Locations to be probed. runTime modifiable!
probeLocations
(0.0014 0.0019 0.0)
(.04 .04 0.0)
(.078 .05 0.0)
(.0611 .0775 0.0)
(.079 .062 0.0)
(.06 .023 0.0)
(.022 .058 0.0)
// Fields to be probed. runTime modifiable!
fields
p
U
T
Regards
Manu
manuc is offline   Reply With Quote
