const qualifier problems
Old   August 17, 2016, 08:55
Default const qualifier problems
Zhiheng Wang
Zhiheng Wang is on a distinguished road
Hi my createField.H has defination of T as
const volScalarField& T = thermo.T();
I want to impliment my code on boundaryCondition correction as
forAll(T.boundaryField()[patchID],i)
T.boundaryField)([patchID][i] = T.boundaryField()[patchID][i]-DT;
-------------------------- (some code for spoces) ........
T.write();
I am getting following error
error: assignment of read-only location ‘(&(&(& T)->Foam::GeometricField<Type, PatchField, GeoMesh>::boundaryField<double,.....
How to resolve this condition I want to correct the temperature T with some differet function based on spices flux. please help
Zhiheng Wang is offline   Reply With Quote
Old   August 17, 2016, 09:37
chriss85 will become famous soon enough
As of OpenFOAM 4.0 you need to use boundaryFieldRef() instead of boundaryField() if you want a non-const access to the boundaries. Same goes for internalField() and internalFieldRef() (and possibly other functions as well).
chriss85 is offline   Reply With Quote
Old   August 17, 2016, 10:48
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
And also:
instead of
use
otherwise it won't even allow you to call boundaryFieldRef().
Zeppo is offline   Reply With Quote
Old   August 17, 2016, 14:18
Jerry
Jerryfan is on a distinguished road
Hi wang,
As others have already mentioned above, you shouldn't use that
const
qualifier. In C++, a variable defined as const-qualifier is ready-only so that you can't change the value of the variable. So in your case, const should be removed.
Jerryfan is offline   Reply With Quote
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
Viscoelastic Fluid Flows using OpenFOAM The solver viscoelasticFluidFoam jovani OpenFOAM Running, Solving & CFD 475 January 13, 2023 08:21
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
k-e & GAMG interFoam Schemitisation Stability Issue JFM OpenFOAM Running, Solving & CFD 3 December 1, 2015 05:58
problem in defining the temperature dependent viscosity!!! adambarfi OpenFOAM Programming & Development 0 March 5, 2013 06:25
