multiphase explicitsolve function in interFoam
Old   September 4, 2016, 11:26
Default multiphase explicitsolve function in interFoam
Abdallah Salem
abdo1984 is on a distinguished road
hello all
I am trying to couple volume of fluid with level set in interFoam (2.3.0). For this purpose, I have to solve this PDE for artificial time not phyiscal time.
ddt(psi) + div.(psi *(1 - psi ) n) = div.(epsilon * (grad(psi) * n) n)
where psi : is level set
n : is the normal to the interface and is already calculated by interFoam
epsilon : is a parameter related to the mesh size (dx/2 )
I thought of using subcycle used in interFoam.
the second term in the left hand side can be hendled by
fvc::flux
-fvc::flux(-phisf, scalar(1.0) - psi ,psiScheme) ,
psi ,
psiScheme
where phisf is the normal flux which is the same as interface.nHatf()
now I have a problem with handling with the right hand side because of grad term. So could you guys please gives me hand to handle such a term as flux in order to use it in explicitSolve function. Thanks alot .
abdo1984 is offline   Reply With Quote
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
[snappyHexMesh] Problem with parallel run of snappyHexMesh Lorenzo92 OpenFOAM Meshing & Mesh Conversion 5 April 15, 2016 04:12
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
