max value in parallel processing
Old   September 5, 2016, 00:46
Default max value in parallel processing
anonymous
cute is on a distinguished road
Hi All,
I am running an application and the mesh was decompose for 16 processors. I submitted my job for parallel processing, but I am not receiving correct max value. I am using the following code where X and XE are defined as volScalarField and calculated before entering the given code:
const volVectorField& pF = mesh.C();
for (int i=0; i<pF.size(); i++)
    if (abs(X[i]-XE[i])>maxDiff)
              maxDiff = fabs(X[i]-XE[i]);
              tempi=i;
Info<< "Diff= " << maxDiff << "  @ i = "<<tempi<<nl<<endl;
I need you help. Please suggest.
Thanks
cute is offline   Reply With Quote
Old   September 5, 2016, 02:55
Ehsan Mahravan
EhsanMh is on a distinguished road
use gMax function.
EhsanMh is offline   Reply With Quote
Old   September 5, 2016, 13:07
anonymous
Thanks, this works partially.
I am alo interested to get the value of tempi at which tempDiff is maximum.
I used
reduce(maxDiff, maxOp<scalar>());
to get maxDiff but I wasn't able to get correct tempi.
Old   September 6, 2016, 00:56
Ehsan Mahravan
I used
HI again,
look at this thread:
http://www.cfd-online.com/Forums/ope...alarfield.html
Old   September 6, 2016, 06:35
anonymous
Please check my code above, I am looking for tempi at which maxDiff is maximum. It is not necessary that tempi is maximum. For example:
processor 1: maxDiff = 180 ; tempi = 245
processor 1: maxDiff = 100; tempi = 3478
processor 1: maxDiff = 187; tempi = 405
processor 1: maxDiff = 89; tempi = 7656
It should be maxDiff = 187; tempi = 405
Thanks.
Old   September 6, 2016, 08:32
Ehsan Mahravan
findMax returns the lable. look at here for examples:
https://github.com/OpenFOAM/OpenFOAM...MaxTemplates.C
good luck
Old   May 23, 2020, 09:45
Wulue is on a distinguished road
hi cute. Have you resolved this issue? I encountered the same problem. could you help me?
Wulue is offline   Reply With Quote
Cavitation around NACA hydrofoil using interPhaseChangeFoam Kozan OpenFOAM Running, Solving & CFD 28 March 11, 2023 23:30
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 17:36
Parallel processing of OpenFOAM cases on multicore processor??? g.akbari OpenFOAM Running, Solving & CFD 31 November 1, 2017 09:25
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 11:58
