multi layerd laplacianfoam
Like Tree1Likes
  • 1 Post By bigphil
Old   September 7, 2016, 11:58
Default multi layerd laplacianfoam
Mohammad Jam is on a distinguished road
Hi
is it possible to solve multi layer medium by laplacianFoam solver?
Mohammad Jam is offline   Reply With Quote
Old   September 7, 2016, 14:10
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Originally Posted by Mohammad Jam View Post
Hi
Do you mean where there are layers of material with different diffusivities?
If so, the answer is no for the default laplacianFoam but it is very easily modified to allow this. The diffusivity (called DT) in laplacianFoam.C is a dimensionedScalar (same value for every cell); you could change this to be a volScalarField that you read from the case: this would allow you to set a different DT for every cell; you could set layers using setFields.
You may need to be careful if there is a large discrete jump in DT across an interface, as the normal gradient would not be defined; however, the default method may be fine depending on what you are interested in.
Philip
alia likes this.
bigphil is offline   Reply With Quote
Old   September 7, 2016, 15:16
Any answer is welcome!
Regards,
Mohammad
Old   September 7, 2016, 15:22
Philip
Hi Phllip
thanks for your kind response,
How can i implement complex shape like closed curve ( NOT ordinary shape like circle ...) by setFields or funkySetFields? is it possible to do?
i want to simulate heat transfer in human eye as i attached its picture.
Regards,
Mohammad
Old   September 8, 2016, 04:08
Mohammad Shakil Ahmmed
ahmmedshakil is on a distinguished road
Hi Jam,
The convenient way for generating mesh for the mentioned structure can be Gambit or GridGen, and then transfer it to OpenFOAM format.
Cheers
shakil
ahmmedshakil is offline   Reply With Quote
Old   September 8, 2016, 07:49
Originally Posted by ahmmedshakil View Post
Hi Jam,
Cheers
shakil
Hi Mohammad
you are right, But every layer of mentioned structure has different value properties e.g. thermal conductivity and i want to implement these properties by funkySetField.
any idea?
Regards,
jam
Multi-region problem using laplacianFoam zfaraday OpenFOAM Pre-Processing 9 March 19, 2023 06:20
Add solar radiation to laplacianFoam aar_out OpenFOAM Programming & Development 2 April 30, 2017 15:12
Single Core vs. Multi Core Issue Traction FLUENT 2 May 14, 2014 13:52
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 19:13
What is multi compoent diffusion radiation.boy FLUENT 0 October 19, 2011 02:44
