Asking Questions about the Flux phi and the source() of fvVectorMatrix
Prev Previous Post   Next Post Next
Old   September 21, 2016, 08:41
Default Asking Questions about the Flux phi and the source() of fvVectorMatrix
Wei
mengweilm425 is on a distinguished road
Dear Foamers,
I am using Foam-dev, and the following questions are associated with the tutorial case 'cavity' using the 'icoFoam' solver.
A 4 by 4 grid was used in order to have a closer look at the variables.
vertices
(0 0 0)
(1 0 0)
(1 1 0)
(0 1 0)
(0 0 0.1)
(1 0 0.1)
(1 1 0.1)
(0 1 0.1)
blocks
hex (0 1 2 3 4 5 6 7) (4 4 1) simpleGrading (1 1 1)
Question 1:
when I was trying to check the 'phi' values using
Info<< " phi " << phi << nl <<endl;
Info<< " phi size " << phi.size() << nl <<endl;
I got the output as follows:
phi dimensions [0 3 -1 0 0 0 0];
internalField nonuniform List<scalar>
24
-2.28233e-06
2.28233e-06
-3.2402e-06
9.57866e-07
-2.28434e-06
-9.55866e-07
-2.28433e-06
-3.94416e-06
6.22649e-06
-5.34147e-06
2.35517e-06
-3.95016e-06
-2.34716e-06
-6.2345e-06
-6.72257e-06
1.29491e-05
-7.99247e-06
3.62507e-06
-6.71657e-06
-3.62306e-06
-1.29511e-05
1.29491e-05
1.65741e-05
1.29511e-05
boundaryField
movingWall
type calculated;
value uniform 0;
fixedWalls
type calculated;
value uniform 0;
frontAndBack
type empty;
value nonuniform 0();
phi size 24
My question is: there are 72 faces including internal and boundary one, why is the phi only defined on the internal faces rather than the boundary? Or how the boundary flux is considered in 'fvm::div(phi, U)'?
Question 2:
I created a new fvVectorMatrix as follows:
fvVectorMatrix UEqn_time_term
fvm::ddt(U)
, and output the source of UEqn_time_term
Info<< " UEqn_time_term.s " << UEqn_time_term.source() << nl << endl;
I got the following numbers:
UEqn_time_term.s
16
(-5.83396e-06 5.74984e-06 0)
(-1.42259e-05 2.43986e-06 0)
(-1.42171e-05 -2.34961e-06 0)
(-5.92331e-06 -5.6699e-06 0)
(-1.00527e-05 2.19123e-05 0)
(-2.40783e-05 8.37173e-06 0)
(-2.41399e-05 -8.28764e-06 0)
(-1.01346e-05 -2.19111e-05 0)
(-1.39378e-05 4.90818e-05 0)
(-3.80295e-05 1.57254e-05 0)
(-3.80131e-05 -1.56865e-05 0)
(-1.39231e-05 -4.90753e-05 0)
(9.96865e-05 3.28844e-05 0)
(7.57897e-05 9.67425e-06 0)
(7.57862e-05 -9.65121e-06 0)
(9.97123e-05 -3.2868e-05 0)
I am wondering why the source of UEqn_time_term is not always '0' as I only introduced 'fvm::ddt(U)'?
Thank you in advance for your help!
Regards,
Wei
mengweilm425 is offline   Reply With Quote
