Rep Power: 10 ![]() |
Hello to all,
I'm going to add the sensitivity equation to my createFields.H the equation is Code:
-A*nu*(n*nabla)u*(n*nabla)u At the end of the file i added Code:
scalar nu = readScalar(db().lookupObject<IOdictionary>("transportProperties").lookup ("nu")); volScalarField sens ( IOobject ( "sensitivity" "alpha", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), -magSf()*nu*snGrad(Ua)*snGrad(U) ); Code:
In file included from /home/roby/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude/postProcess.H:129:0, from myAdjointShapeOptimizationFoam.C:72: ./createFields.H: In function ‘int main(int, char**)’: ./createFields.H:112:34: error: ‘patch’ was not declared in this scope vectorField U_n = (U & patch().nf())*patch().nf(); // Normale ^ ./createFields.H:118:31: error: ‘db’ was not declared in this scope scalar nu = readScalar(db().lookupObject<IOdictionary>("transportProperties ^ ./createFields.H:118:58: error: expected primary-expression before ‘>’ token scalar nu = readScalar(db().lookupObject<IOdictionary>("transportProperties ^ ./createFields.H:118:83: error: request for member ‘lookup’ in ‘("transportProperties")’, which is of non-class type ‘const char [20]’ nu = readScalar(db().lookupObject<IOdictionary>("transportProperties").lookup ^ ./createFields.H:132:12: error: ‘magSf’ was not declared in this scope -magSf()*nu*snGrad(Ua_t)*snGrad(U_t) ^ ./createFields.H:132:28: error: ‘snGrad’ was not declared in this scope -magSf()*nu*snGrad(Ua_t)*snGrad(U_t) ^ ./createFields.H:132:28: note: suggested alternative: In file included from /home/roby/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude/fvcSnGrad.H:88:0, from /home/roby/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude/fvc.H:51, from /home/roby/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude/fvCFD.H:8, from myAdjointShapeOptimizationFoam.C:48: /home/roby/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude/fvcSnGrad.C:88:1: note: ‘Foam::fvc::snGrad’ snGrad ^ In file included from myAdjointShapeOptimizationFoam.C:78:0: createFields.H:112:34: error: ‘patch’ was not declared in this scope vectorField U_n = (U & patch().nf())*patch().nf(); // Normale ^ createFields.H:118:31: error: ‘db’ was not declared in this scope scalar nu = readScalar(db().lookupObject<IOdictionary>("transportProperties ^ createFields.H:118:58: error: expected primary-expression before ‘>’ token scalar nu = readScalar(db().lookupObject<IOdictionary>("transportProperties ^ createFields.H:118:83: error: request for member ‘lookup’ in ‘("transportProperties")’, which is of non-class type ‘const char [20]’ nu = readScalar(db().lookupObject<IOdictionary>("transportProperties").lookup ^ createFields.H:132:12: error: ‘magSf’ was not declared in this scope -magSf()*nu*snGrad(Ua_t)*snGrad(U_t) ^ createFields.H:132:28: error: ‘snGrad’ was not declared in this scope -magSf()*nu*snGrad(Ua_t)*snGrad(U_t) ^ createFields.H:132:28: note: suggested alternative: In file included from /home/roby/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude/fvcSnGrad.H:88:0, from /home/roby/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude/fvc.H:51, from /home/roby/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude/fvCFD.H:8, from myAdjointShapeOptimizationFoam.C:48: /home/roby/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude/fvcSnGrad.C:88:1: note: ‘Foam::fvc::snGrad’ snGrad ^ /home/roby/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8: set di istruzioni per l'obiettivo "Make/linux64GccDPInt32Opt/myAdjointShapeOptimizationFoam.o" non riuscito make: *** [Make/linux64GccDPInt32Opt/myAdjointShapeOptimizationFoam.o] Errore 1 Last edited by FlyBob91; November 16, 2016 at 04:54. |
Ok i added these line above runTime.write(); in the shapeOptimization.C file
// Sensitivity calculation word patchName = "wing"; label patchID = mesh.boundary().findPatchID(patchName); scalarField temp = (U.boundaryField()[patchID].snGrad() & Ua.boundaryField()[patchID].snGrad()); sensitivity.boundaryField()[patchID] = mesh.boundary()[patchID].magSf() * (temp); I added this lines at the end of the file Code:
volScalarField sensitivity ( IOobject ( "sensitivity", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), ****************** ) Any idea? Best Regards, Roberto |
Sorry for the bump, i'm a bit disperate
Jeroen
Rep Power: 9 ![]() |
Check chapter 3.4: http://www.tfd.chalmers.se/~hani/kur...ortAdjoint.pdf
#5 | |
I have already read that article but it was a very simple case compared to mine. Here the solution of what i did few days ago, maybe it can help someone. I created a file where i wrote the sensitivity equation and then i initializied it in this manner in the createFields.H Code:
// PRIMAL NORMAL GRADIENT volVectorField wallGradU ( IOobject ( "wallGradU", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), mesh, dimensionedVector ( "wallGradU", U.dimensions()/dimLength, vector::zero ) ); // ADJOINT NORMAL GRADIENT volVectorField wallGradUa ( IOobject ( "wallGradUa", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), mesh, dimensionedVector ( "wallGradUa", Ua.dimensions()/dimLength, vector::zero ) ); // FACE AREA volScalarField areaMag ( IOobject ( "areaMag", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedScalar("areaMag", dimLength*dimLength, 0.0) ); // SENSITIVITY volScalarField Sens ( IOobject ( "Sens", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedScalar("Sens", dimLength*dimLength*dimLength*dimLength/(dimTime*dimTime*dimTime), 0.0) ); Roberto |
conjugateHeatFoam + interFoam | farhagim | OpenFOAM Programming & Development | 15 | July 19, 2016 07:55 |
chtMultiRegionSimpleFoam | samiam1000 | OpenFOAM Running, Solving & CFD | 39 | March 31, 2016 08:43 |
chtMultiRegionSimpleFoam: strange error | samiam1000 | OpenFOAM Running, Solving & CFD | 26 | December 29, 2015 22:14 |
Adjoint sensitivity on specified surface | robyTKD | OpenFOAM Programming & Development | 0 | April 29, 2013 05:05 |
Help with chtMultiRegionFoam | jbvw96 | OpenFOAM Running, Solving & CFD | 2 | December 26, 2010 17:16 |
