November 27, 2016, 21:40 |
Source term addition through fvOptions
DongHo
Rep Power: 12 |
Hi Foamers
I have a question about fvOPtions. Actually I add a source term trough fvOptions to pisoFoam (V2.3). The source term will be added after a momentum predictor procedure as below. U = HbyA - rAU*fvc::grad(p) + rAU*fvOptions(U); However, when this source term is added, the following error comes up. pisoVC2Foam is a new developed solver for the consideration of Vorticity Confinement Method. I will appreciate it if you can give me comments to resolve this problem. Thanks pisoVC2Foam.C: In function ‘int main(int, char**)’: pisoVC2Foam.C:211:64: error: no match for ‘operator=’ in ‘U = Foam:perator+(const Foam::tmp<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh> >&, const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = Foam::Vector<double>]((*(const Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >*)(& Foam:perator*(const Foam:imensionedField<double, Foam::volMesh>&, const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = Foam::Vector<double>]((*(const Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >*)(& Foam::fv:ptionList:perator()(Foam::GeometricFi eld<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = Foam::Vector<double>]((* & U))))))))’ pisoVC2Foam.C:211:64: note: candidates are: /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricField.C:1080:6: note: void Foam::GeometricField<Type, PatchField, GeoMesh>:perator=(const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricField.C:1080:6: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ to ‘const Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&’ /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricField.C:1105:6: note: void Foam::GeometricField<Type, PatchField, GeoMesh>:perator=(const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricField.C:1105:6: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ to ‘const Foam::tmp<Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> >&’ /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricField.C:1141:6: note: void Foam::GeometricField<Type, PatchField, GeoMesh>:perator=(const Foam::dimensioned<Form>&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricField.C:1141:6: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ to ‘const Foam::dimensioned<Foam::Vector<double> >&’ /opt/openfoam230/src/finiteVolume/lnInclude/readPISOControls.H:3:15: warning: unused variable ‘nOuterCorr’ [-Wunused-variable] /opt/openfoam230/src/finiteVolume/lnInclude/readPISOControls.H:15:16: warning: unused variable ‘transonic’ [-Wunused-variable] |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 17:25 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
