Adding a Source Term to an User Defined transport equation
Old   January 1, 2017, 18:00
Default Adding a Source Term to an User Defined transport equation
rma
Anonymous
rma is on a distinguished road
Hello everyone,
I have added a new transport equation to an existing solver, and I have all the bits working but the source term.
That source term takes the following form: div(K*scalarField*vectorField)
with K being a constant.
Therefore, I have created in createFields.H an volVectorField countaining that product, so I can easily take the divergence afterwards in the solvers's '.C' file.
volVectorField sourceTerm
IOobject
"sourceTerm",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
Then, in the '.C' file of the solver I do:
sourceTerm=K*scalarField*vectorField;
fvScalarMatrix uds1Eqn
fvm::ddt(uds1)
- fvm::laplacian(D_uds1, uds1)
- fvc::div(sourceTerm)
uds1Eqn.solve();
Everything compiles fine, but when I am running the solver, I get the following error:
--> FOAM FATAL IO ERROR:
attempt to read beyond EOF
file: /home/rma/OpenFOAM/Pruebas/case/system/fvSchemes.divSchemes.div(sourceTerm) at line 33.
From function ITstream::read(token&)
in file db/IOstreams/Tstreams/ITstream.C at line 83.
FOAM exiting
However, the fvSchemes file does have that scheme specified:
divSchemes
default Gauss upwind;
div(phi,U) Gauss limitedLinearV 1;
div(sourceTerm) Gauss upwind;
I don't really know how to proceed from here, maybe that is not the way I am suppossed to create a source term, so I would really appreciate if someone could help me with this problem.
Thank you very much.
rma is offline   Reply With Quote
Old   January 2, 2017, 05:55
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
http://cfd.direct/openfoam/user-guid...19-1400004.4.3
divSchemes
requires you to specify "the (volumetric) flux of velocity on the cell faces for constant-density flows and the mass flux for compressible flows"
div(phi, sourceTerm) Gauss upwind;
Depending on the physical meaning of the term you might be happy with
div(sourceTerm)         Gauss linear;
Zeppo is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Reaction Source Term in Steady Species transport equation cfdvenkatesh Main CFD Forum 0 August 19, 2010 09:28
