Adding of source term in momentum equation required any changes in PISO algorith
Old   January 9, 2017, 04:25
Smile Adding of source term in momentum equation required any changes in PISO algorith
shadab ilahi
shadabdyn is on a distinguished road
Hello everyone,
I need to add the gravity settling effect delrho*g*phi to the existing self-made code. and I am using the Piso algorithm. so I added delrho*g*phi at the solve momentum predictor step. here I choose g as a volume vector defined in the create field properties simultaneously additional initial property in 0 folder of the case directory and density difference as constant transport properties ( dimensional scalar in create property.h file). when I compile the Source code it is running fine without any error..when I run twice it is showing up to date.
So I am asking that what I have done is correct or not. I am adding my source code also below. I am attaching a picture of my governing equation also.
// Pressure-velocity PISO corrector
for (int corr=0; corr<nCorr; corr++)
// Momentum predictor
tmp<fvVectorMatrix> UEqn
- fvm::laplacian(nu1, U) -fvc::div(nu1*dev(fvc::grad(U)().T())) -fvc::div(SigmaL)
UEqn().relax();
solve(UEqn() == -fvc::grad(p)+delrhog*c); //+delrhog*c
p.boundaryField().updateCoeffs();
volScalarField rUA = 1.0/UEqn().A();
U = rUA*UEqn().H();
UEqn.clear();
phi = fvc::interpolate(U) & mesh.Sf();
adjustPhi(phi, U, p);
// Store pressure for under-relaxation
p.storePrevIter();
// Non-orthogonal pressure corrector loop
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
fvScalarMatrix pEqn
fvm::laplacian(rUA, p) == fvc::div(phi)
pEqn.setReference(pRefCell, pRefValue);
pEqn.solve();
if (nonOrth == nNonOrthCorr)
phi -= pEqn.flux();
# include "continuityErrs.H"
// Explicitly relax pressure for momentum corrector
p.relax();
// Momentum corrector
U -= rUA*fvc::grad(p);
U.correctBoundaryConditions();
up to best of my knowledge we should'nt add I source term at momentum corrector step?
Thanks in advance.
shadabdyn is offline   Reply With Quote
Old   January 14, 2017, 22:39
Pete Bachant
pbachant is on a distinguished road
Looks like your image isn't showing up. Also, please put your code in the [CODE] blocks so it's in monospace font with indentation.
Home | Twitter | GitHub
pbachant is offline   Reply With Quote
Old   January 15, 2017, 01:16
shadab ilahi
Thank u pbachant for your reply. I hope now this image and code could help u to understand my problem.
        // Pressure-velocity SIMPLE corrector
            UEqn().relax();
            U = rUA*UEqn().H();
            UEqn.clear();
            p.storePrevIter();
                fvScalarMatrix pEqn
                pEqn.solve();
                    phi -= pEqn.flux();
            p.relax();
Adding a Source Term to Pressure equation pEqn in SimpleFoam oscar_urri OpenFOAM 11 February 22, 2018 17:52
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 19:53
