How to access p and U within rotatingMotion.C/H
Old   November 30, 2016, 18:24
Default How to access p and U within rotatingMotion.C/H
waku2005 is on a distinguished road
Hi all,
I try to modify "rotatingMotion.C/H" of solidBodyMotionFunctions as those can calculate moment vector from p(pressure) and U(viscousity).
Thus, I hope to obtain p and U from previous timestep results.
I'd like to know the way to access such results if available.
Another question. rotatingMotion class has a constructer as below.
It uses runTime as time_, and runTime is a objectRegistory.
I can access to p and U via runTime(i.e.,time_) ?
Thanks in advance,
waku2005
        //- Construct from components
        rotatingMotion
            const dictionary& SBMFCoeffs,
            const Time& runTime
        //- Construct and return a clone
        virtual autoPtr<solidBodyMotionFunction> clone() const
            return autoPtr<solidBodyMotionFunction>
                new rotatingMotion
                    SBMFCoeffs_,
                    time_
waku2005 is offline   Reply With Quote
Old   December 2, 2016, 03:51
Nima Samkhaniani
nimasam is on a distinguished road
you can use following structure to read U or p from solver:
const volVectorField& U = db().lookupObject<volVectorField>("U");
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   December 4, 2016, 19:43
Hi, nimasam
Thank you for your reply.
I added "#include "volFields.H"" and the line you mentioned.
#include "DDrotatingMotion.H"
#include "addToRunTimeSelectionTable.H"
#include "mathematicalConstants.H"
#include "volFields.H"  //<-- added
// * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * * //
Foam::septernion
Foam::directDrivenMotionFunctions::DDrotatingMotion::transformation() const
    scalar t = time_.value();
    // Rotation around axis
    scalar angle = omega_->integrate(0, t);
    const volVectorField& U = db().lookupObject<volVectorField>("U");  //<-- added
    quaternion R(axis_, angle);
    septernion TR(septernion(-origin_)*R*septernion(origin_));
    DebugInFunction << "Time = " << t << " transformation: " << TR << endl;
    return TR;
Unfortunately build was failed as bellow:
directDrivenMotionFunctions/DDrotatingMotion/DDrotatingMotion.C: In member function ‘virtual Foam::septernion Foam::directDrivenMotionFunctions::DDrotatingMotion::transformation() const’:
directDrivenMotionFunctions/DDrotatingMotion/DDrotatingMotion.C:82:34: error: ‘db’ was not declared in this scope
directDrivenMotionFunctions/DDrotatingMotion/DDrotatingMotion.C:82:63: error: expected primary-expression before ‘>’ token
# DDrotatingMotion.C (and .H) is my own function file but they are still the same with the original rotaitngMotion.C (and .H).
How do I access to db() ?
Best regards
waku2005
Old   December 5, 2016, 01:34
Hi
I changed the line to:
    const volVectorField& U = time_.db().lookupObject<volVectorField>("U");
and the build was in success, but failed with runtime error as bellow:
--> FOAM FATAL ERROR:
    request for volVectorField U from objectRegistry mixerVesselAMI2D failed
    available objects of type volVectorField are
0()
db() has no registerdObject ?
waku2005
Old   January 18, 2017, 04:13
Alexander Nekris
Neka is on a distinguished road
Hi waku2005,
I'm struggling with a similar Problem.
I have to define an additional function in the class multiComponentMixture and for this new function I need to access the volScalarField rho at each time step.
Did you succeed to resolve this issue?
Best regards
Neka
Neka is offline   Reply With Quote
Old   January 26, 2017, 12:03
Alexander Nekris
Here is one possibility:
Accessing fields calculated in a solver within a class
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 15:13
DPM, access particle data - number of tries wsaac Fluent UDF and Scheme Programming 1 July 31, 2018 02:40
Is there a way to access the gradient limiter in Fluent ? CFDYourself FLUENT 1 February 16, 2016 05:49
Online libraries - with access to Journals momentum_waves Main CFD Forum 2 December 12, 2007 10:08
Error: access: unbound variable,HELP sudhakar FLUENT 0 January 15, 2007 23:21
