Compute the gradient for use in BCs
Old   February 13, 2018, 09:02
Post Compute the gradient for use in BCs
turbulo is on a distinguished road
I'm fairly new to OpenFOAM and would like to know if it possible to use the gradient operator to define a new boundary condition for velocity. When I use
fvc::grad(U1)
the compiler says:
 'grad' is not a member of 'Foam::fvc'
There seems to be no other issue with the code if I remove the part involving the gradient.
I've taken the already existing movingWallVelocity BC and modified it to get the new BC. I'm fairly good at C++ but still not familiar enough with OpenFOAM's structure to figure this out. Any help or hint in the right direction would be really appreciated.
turbulo is offline   Reply With Quote
boundary condition, openfoam
Temperature gradient for the internal Field. Philipp Dietrich OpenFOAM Programming & Development 0 July 2, 2014 03:15
WSS and normal velocity gradient for the slanted pipe wanna88 FLUENT 2 October 1, 2012 22:34
vortex cause pressure gradient or pressure gradient induce vortex? fruitkiwi Main CFD Forum 4 June 12, 2012 01:12
How to compute gradient for non-orthogonal grids? Paul Hsieh Main CFD Forum 3 November 11, 2003 04:52
how to compute the gradient of a function zhanglei Main CFD Forum 2 January 10, 2001 08:11
