[HowTo]pointVectorField to volVectorField ???
Like Tree2Likes
  • 1 Post By frobaux
  • 1 Post By frobaux
Old   January 27, 2017, 09:20
Question [HowTo]pointVectorField to volVectorField ???
ycui is on a distinguished road
Dear Foamer:
I want to read a flow field from Tecplot data into the OpenFOAM. The fluid information is based on fluid nodes, however, in OpenFOAM the fluid information is based on cells. So I want to do an interpolation.
The way I think so far is that I read the fluid information into a pointVectorField, then interpolate to the volVectorField. In the creatFields.H, I wrote:
pointVectorField UPoint
IOobject
"UPoint",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
pointMesh
volVectorField U
IOobject
"U",
runTime.timeName(),
mesh,
IOobject::NO_READ,
mesh
Then I want to do the Interpolation in this way:
U = pointVolInterpolation::interpolate(UPoint);
But during compiling error said it cannot find the pointVolInterpolation.
I'm not sure if I doing in the right way or not Can anyone help me on this problem
Thanks in advance!
ycui
ycui is offline   Reply With Quote
Old   January 27, 2017, 09:41
floquation's Avatar
Kevin van As
floquation will become famous soon enough
I have never worked with the interpolation class, so I do not know how to use it.
However, I do know that in "dynamicRefineFvMesh" there is a local implementation to convert between cell data and point data.
Have a look at the method "maxPointField", "maxCellField" and/or "cellToPoint" [path for OF4.0]:
${FOAM_SRC}/dynamicFvMesh/dynamicRefineFvMesh
Perhaps it inspires you to do it yourself.
floquation is offline   Reply With Quote
Old   January 27, 2017, 10:26
Thank you for the reply.
It seems there is no function like pointToVol after version 1.6, only has function volToPoint.
Old   February 1, 2017, 04:49
I have fixed this problem, few comments:
1. copy the pointVolInterpolation from an older version of OF, then compile;
2. pointVolInterpolation is a namespace and cannot be defined in creatFields.H, should be defined in other location;
3. define the point data as pointVectorFields with pointMesh, and define the volume data as volVectorFields with mesh, then do the interpolation.
4. the difference before and after the interpolation depends on the velocity fluctuations.
Old   October 2, 2019, 01:41
krishna kant
kk415 is on a distinguished road
Hello YCUI,
I am trying to do the same. I copied the pointVectorField to my solver. I am getting the following error:
undefined reference to `Foam:ointVolInterpolation:ointVolInterpolatio n(Foam:ointMesh const&, Foam::fvMesh const&)'
My piece of code
const pointMesh pMesh(mesh);
volPointInterpolation vpi(mesh);
pointVectorField pointn = vpi.interpolate(gradPsi);
pointVolInterpolation pvi(pMesh, mesh);
Also these header files are defined before main function
#include "volPointInterpolation.H"
#include "pointVolInterpolation.H"
#include "pointMesh.H"
#include "pointFields.H"
kk415 is offline   Reply With Quote
Old   October 3, 2019, 10:04
Fabien Robaux
frobaux is on a distinguished road
I don't use the pointVolInterpolation but a function called interpolatePointToCell inside a loop
The loop looks like:
forAll(mesh , idCell)
      gradPsiAtCell[idCell] = interpolatePointToCell(gradPsi, idCell)
where gradPsi is of type pointScalarField and gradPsiAtCell of type volScalarField (works also for vector fields)
and you need to
 #include "interpolatePointToCell.H"
Hope it helps!
Fabien
kk415 likes this.
frobaux is offline   Reply With Quote
Old   October 4, 2019, 05:17
krishna kant
Hello Fabian,
Thanks for your answer. It works beautifully. Can I get a little insight of the code interpolatepointToCell(trying to do it myself also but so far no success). Like VolPointInterpolation and PointVolInterpolation interpolates using inverse distance weight function. what does interpolatepointToCell do ?
Old   October 4, 2019, 06:38
Fabien Robaux
To be honnest I didn't look into the code either. A fast check into the code show that its seems to be a simple average of all the values at the points surrounding the cell.
template<class Type>
Type Foam::interpolatePointToCell
    const GeometricField<Type, pointPatchField, pointMesh>& ptf,
    const label celli
    const primitiveMesh& mesh = ptf.mesh()();
    // get the cell from the indice of the cell
    const cell& cFaces = mesh.cells()[celli];
    // list of point surounding the cell
    labelHashSet pointHad(10*cFaces.size());
    Type sum = Zero;
    // for all face "f" of the input cell
    forAll(cFaces, i)
        const face& f = mesh.faces()[cFaces[i]];
        // for all facePoint "fp" of the face, v being the global indice of that point.
        forAll(f, fp)
            label v = f[fp];
            if (pointHad.insert(v)) // I guess that it inserts only if not already
                                             // present and return true in that case
                sum += ptf[v];
    return sum/pointHad.size();
Note that I have added the comments, so they are maybe not perfectly accurate.
From this, it would be very easy to copy and modify to have an inverse distance wieghting. Something like
                const scalar dist=mag(mesh().points()[v]-cFaces.centre())
                sum += ptf[v]*dist;
                sumDist+ = dist
return sum/sumDist
Note that the code was not compiled and I'm not sure about mesh().points()[v].
Fabien
kk415 likes this.
Interpolation of a volVectorField onto processor patches Mithrandirrr OpenFOAM Programming & Development 2 April 5, 2023 17:36
making a volVectorField sina_mech OpenFOAM Programming & Development 7 July 7, 2016 14:49
Multiplication of two volVectorField ChGr OpenFOAM Programming & Development 1 May 30, 2016 11:08
copy/write a same volVectorField to every time step folder hy1112006 OpenFOAM Programming & Development 0 April 18, 2016 22:33
Initialize a uniform 0 volVectorField Schag OpenFOAM 3 August 26, 2009 10:08
