February 6, 2017, 04:16 |
Converting a tecplot file to OpenFOAM format
Alex Landsberg
Hello guys
I am trying to write a converter for 2D cases from tecplot to OpenFOAM. The file consists of the list of points and list of connectivity for each cell. The header specifies that the elements are of type quad. I read the points and extrude them in the z direction as requested by OpenFOAM 2D format. I then read the connectivity for cells adding points in the z direction in order to have hex shape. In paraview the mesh looks pretty good but when i run checkMesh it failed to check the topology and got an error with the cellpoints method. Is it a face orientation problem ? Thanks for your help |
cellpoints, converter to openfoam, face orientation |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
