December 16, 2013, 17:42 |
What is cmptMag?
Canakkale Dardanelspor
Rep Power: 13 |
Hi
Could anyone please tell me what cmptMag function is for? Code:
Form Foam::cmptMag ( const VectorSpace< Form, Cmpt, nCmpt > & vs ) inline Many thanks in advance. |
December 18, 2013, 07:23 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hallo,
First of all, abs is not being used as a function in the FOAM namespace, as it is called mag instead. Consider a vector v(-1, -1, -1), the mag(v) is the square root of 3, i.e. the two norm. If you instead do vector w = Foam::cmptMag(v) you will get w = (1, 1, 1). Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
March 19, 2019, 08:50 |
abs not working for me
#3 | |
Rep Power: 8 |
I did "volVectorField U1CmptMag = Foam::cmptMag(U1);" thank you |
