simpleFoam body forces wedge BC interation!
Like Tree1Likes
  • 1 Post By piu58
Old   March 27, 2017, 13:22
Default simpleFoam body forces wedge BC interation!
OpenFoam
CFD-Lover is on a distinguished road
Hi All,
I am trying to manipulate a volume source term that was add to the simpleFoam solver to simulate the flow over a horizontal axis wind turbine. The governing equations used in the code is as follows;
The elementary lift and drag forces on the blade section are given by:
The axial and circumferential forces are;
The circumferential force can be further analyzed to the y and z directions of the Cartesian grid:
If the rotor is composed by B blades, the forces per unit surface will be;
The code was tested and validated successfully and all simulations were done in 3D. My aim is to apply the boundary condition wedge i.e. axisymmertric simulations to save some computational cost. However, the volume force terms programmed in the source code using the above equation are in 3D. I am currently having an issue on which source term should be excluded to be able to make it axisymmetric. Does anyone understand my question here? Can anyone help or suggest any document might help me to get it to work in Axisymmetric?
Thank you again for your time.
CFD-Lover is offline   Reply With Quote
Old   March 27, 2017, 14:16
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
My 2C:
Without changing anything at the simulation you may transform your problem into an axialsymmetric *manually*, with replacing the x coordinate by
log(r/r_i). The coefficents are not correct for this geometry. You may transform the coefficients, or - may be simpler - export the velocities and forces and re-transform them to x/y. In this retransformed system all stream values are at the right place and the coefficients may calculated bu numerical integration / simple summation.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 27, 2017, 14:38
OpenFoam
Hello Pilz,
Thank you for the kind clarifications and help. I don't fully understand how would I replace the x-coordinates by log(r/r_i) .
log(r/r_i).
I definitely agree with you that the coefficients are not correct since the wedge boundary condition requires 5 degree extrusion.
Unclear how would I transform them if they are already incorrect from the axisymmertic simulations?
Thanks again.
Old   March 27, 2017, 15:04
OpenFoam
To be more specific, here are the results of the forces and velocity for both simulations i.e. Axisymmetric and 3D results.
Axi.tar.gz
3Dsimulation.tar.gz
Thanks in advance,
Old   March 28, 2017, 08:57
OpenFoam
It seems that no one in the CFD-Online knows how the wedge BC works.
Old   April 1, 2017, 01:43
piu58's Avatar
Uwe Pilz
I look at your simulation the next few days and try to find out something. Please give me some time for that.
CFD-Lover likes this.
Uwe Pilz
Old   April 2, 2017, 01:20
piu58's Avatar
Uwe Pilz
I only have experiences with changing a 2D geometry in a cylindric one with the help of MakeAxialMesh. The tool needs to be added to a standard installation:
http://openfoamwiki.net/index.php/Contrib_MakeAxialMesh
The tool warps a 2d geometry in an axialsymetric one. The result is still 3d, that means 1 cell thick in radial direction (was the z direction). The wedge boundary condition has to be used at these boundaries. As far as I understand this b.c. takes into account that the planes are not parallel anymore. So "empty" cannot be used.
You don't need to use that tool. It is not too hard to create a axial symmetric geometry form scratch. Start with a wegde and add hex elements which get larger in r direction. The wedge b.c. has to be used too.
In short: The geometry remains 3d as always in openfoam.
Uwe Pilz
Old   April 2, 2017, 18:15
OpenFoam
Dear Pilz,
Thanks again for your time and clarifications. My issue is not that I was not able to create an axiysmmetric mesh from a 2D geometry but instead the main issue is that the three body forces introduced have to be adjusted in the code in order to perform axisymmetric simulations. I need to reduce the problem into two dimensions through the three body forces introduced earlier i.e. fx, fy, fz. I will provide more detail tomorrow so that you can understand what am trying to do.
Thanks again,...
Old   April 19, 2017, 18:44
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
I think that you need to assume the forces are uniformly distributed along the circumferential direction.
Hope that helps,
tareqkh is offline   Reply With Quote
Estimating drag and lift forces on rectangular solid body in Abaqus ismailqeshta Main CFD Forum 0 November 20, 2016 00:58
water entry wedge shape body mohammadizadi STAR-CCM+ 2 January 19, 2016 13:23
strong body forces Ankan Main CFD Forum 0 August 2, 2005 02:13
Forces on spherical body Wen Long Main CFD Forum 0 June 29, 2002 21:21
Body Forces Thomas P. Abraham Main CFD Forum 1 April 21, 1999 21:24
