April 7, 2017, 12:26 |
cannot compile solver
Ricardo
Rep Power: 14 |
Hello all,
I am having trouble compiling an application on a university cluster which had originally compiled without any trouble. Background, I originally compiled and ran the code without any trouble. Couple of months later (NOW) I tried to recomplie again, but now I keep getting an error message. My guess is that the compiler version was changed and its the reason why I get the message, but I am not sure about this. Can anyone help? This is the message I get: OF: Version 2.4.0 Code:
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/meshTools/lnInclude -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/transportModels/incompressible/lnInclude -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/sampling/lnInclude -I/data/users/ricarm3/OpenFOAM/ricarm3-2.4.0/boundMinMax/lnInclude -I/data/users/ricarm3/OpenFOAM/ricarm3-2.4.0/platforms/linux64GccDPOpt/lib -IlnInclude -I. -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/SbmFoamRM.o -L/data/apps/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib \ -lfiniteVolume -lmeshTools -lfvOptions -lsampling -L -L/libfbsdmalloc.o -lOpenFOAM -ldl -lm -o /data/users/ricarm3/OpenFOAM/ricarm3-2.4.0/platforms/linux64GccDPOpt/bin/SbmFoamRM Make/linux64GccDPOpt/SbmFoamRM.o: In function `Foam::fvMatrix<Foam::Vector<double> >::solveSegregated(Foam::dictionary const&)': SbmFoamRM.C:(.text._ZN4Foam8fvMatrixINS_6VectorIdEEE15solveSegregatedERKNS_10dictionaryE[_ZN4Foam8fvMatrixINS_6VectorIdEEE15solveSegregatedERKNS_10dictionaryE]+0x4a6): undefined reference to `Foam::lduMatrix::solver::normFactor(Foam::Field<double> const&, Foam::Field<double> const&, unsigned char) const' collect2: error: ld returned 1 exit status make: *** [/data/users/ricarm3/OpenFOAM/ricarm3-2.4.0/platforms/linux64GccDPOpt/bin/SbmFoamRM] Error 1 |
April 10, 2017, 20:38 |
Ricardo
Rep Power: 14 |
Hi All, I am having trouble compiling a solver. When I run wmake I get the following error
SOURCE=SbmFoamRM.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/meshTools/lnInclude -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/transportModels/incompressible/lnInclude -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/sampling/lnInclude -I/data/users/ricarm3/OpenFOAM/ricarm3-2.4.0/boundMinMax/lnInclude -I/data/users/ricarm3/OpenFOAM/ricarm3-2.4.0/platforms/linux64GccDPOpt/lib -IlnInclude -I. -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/SbmFoamRM.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/meshTools/lnInclude -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/transportModels/incompressible/lnInclude -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/sampling/lnInclude -I/data/users/ricarm3/OpenFOAM/ricarm3-2.4.0/boundMinMax/lnInclude -I/data/users/ricarm3/OpenFOAM/ricarm3-2.4.0/platforms/linux64GccDPOpt/lib -IlnInclude -I. -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/data/apps/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/SbmFoamRM.o -L/data/apps/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib \ -lfiniteVolume -lmeshTools -lfvOptions -lsampling -L -lboundMinMax -lOpenFOAM -ldl -lm -o /data/users/ricarm3/OpenFOAM/ricarm3-2.4.0/platforms/linux64GccDPOpt/bin/SbmFoamRM Make/linux64GccDPOpt/SbmFoamRM.o: In function `Foam::fvMatrix<Foam::Vector<double> >::solveSegregated(Foam::dictionary const&)': SbmFoamRM.C:(.text._ZN4Foam8fvMatrixINS_6VectorIdEEE15solveSegregatedERKNS_10dictionaryE[Foam::fvMatrix<Foam::Vector<double> >::solveSegregated(Foam::dictionary const&)]+0x7af): undefined reference to `Foam::lduMatrix::solver::normFactor(Foam::Field<double> const&, Foam::Field<double> const&, unsigned char) const' collect2: ld returned 1 exit status make: *** [/data/users/ricarm3/OpenFOAM/ricarm3-2.4.0/platforms/linux64GccDPOpt/bin/SbmFoamRM] Error 1 My Make/options file includes the OpenFOAM/lnInclude which contains the link to the ldumatrix.H so I am not sure what to do Code:
EXE_INC = \ -I$(LIB_SRC)/OpenFOAM/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/transportModels/incompressible/lnInclude \ -I$(LIB_SRC)/sampling/lnInclude \ -I$//data/users/ricarm3/OpenFOAM/ricarm3-2.4.0/boundMinMax/lnInclude \ -I$(FOAM_USER_LIBBIN) \ EXE_LIBS = \ -lfiniteVolume \ -lmeshTools \ -lfvOptions \ -lsampling \ -L$(FOAM_USER_LIBIN) \ -lboundMinMax |
April 20, 2017, 06:06 |
Cannot compile
Max
Rep Power: 9 |
This may sound like a stupid idea and I hope you already tried it, but I had some time ago a similar issue were a turbulence model just wouldnt compile. I checked all my linkages etc and couldnt find the error. Finally I run "wclean" and "wmake" and miraculously it worked. If this still doesnt fix it, could you provide more information on what you are compiling. If it is a turbulence model, solver i.e. Furthermore could you provide your Make file and the folder structure on how it is stored. I see you reference boundMinMax. If this is also a part build by you, try compiling this one first. Good luck |
compiling error(s), fvmatrix, ldumatrix, solver |
How to compile a new solver in OpenFOAM-2.1.0? | sandy | OpenFOAM Programming & Development | 24 | July 27, 2016 04:10 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
How to compile an unsteady solver based on solver of MRFSimpleFoam? | renyun0511 | OpenFOAM Running, Solving & CFD | 0 | April 27, 2010 11:16 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
