Write Cell Volumes and Velocities for each TimeStep
Old   April 19, 2017, 04:35
Default Write Cell Volumes and Velocities for each TimeStep
Sebastian Trunk
sisetrun is on a distinguished road
Hello everybody,
I am write a little post-processing tool which writes out the cell volumes and the velocities in the cells for a specific region in the domain.
Since I am only interested in a small part of my domain, I define a distance from z_min to z_max in an so called CoordinatesDict in the constant directory. I want to write the data in a .dat file to proceed working with python.
At the moment the code looks like this...
// This file is based on OpenFOAM.
// Description
//    Write mesh cell volumes in volumes.dat file and velocity in
//    velocity.dat file in current folder.
#include "OFstream.H"
#include "argList.H"
#include "timeSelector.H"
#include "Time.H"
#include "fvMesh.H"
#include "vectorIOField.H"
#include "volFields.H"
#include "surfaceFields.H"
//#include "fvCFD.H"
using namespace Foam;
int main(int argc, char *argv[])
    timeSelector::addOptions();
#   include "setRootCase.H"
    Info << "\n***EXTRACT CELL VOLUMES AND VELOCITIES***\n" << endl;
    Info << "This applications is extacting the volumes and the velocities from a region in the domain\n" << endl;
#   include "createTime.H"
    instantList timeDirs = timeSelector::select0(runTime, args);
#   include "createMesh.H"
#   include "createFields.H"
    Info << "1) Reading all volumes..." << endl;
    Info << "Extracting cells between z = " << z_min.value();
    Info << " and z = " << z_max.value() << endl;
    OFstream volumes("volumes_" + runTime.timeName() + ".dat");
    forAll(mesh.C(), idx)
        if (mesh.C()[idx].component(2) >= z_min.value())
            if (mesh.C()[idx].component(2) <= z_max.value())
                    volumes << idx << ' ' << mesh.V()[idx] << ' ' << mesh.C()[idx] << endl;
    Info << "Volumes DONE...\n" << endl;
    Info << "2) Reading velocities...\n" << endl;
    forAll(timeDirs, timeI)
        runTime.setTime(timeDirs[timeI], timeI);
        Info<< "Time = " << runTime.timeName() << endl;
        #include "createMesh.H"
        #include "createFields.H"
        OFstream velocity("velocity_" + runTime.timeName() + ".dat");
        //Extract the z component of the cell centers
        Info << "Writing data to the files velocity_" + runTime.timeName() + ".dat" << "\n" << endl;
                  velocity << idx << ' ' << U[idx].component(0) << ' ' <<  U[idx].component(1) << ' ' << U[idx].component(2) << endl;
    Info << "Writing done \n" << endl;
    return 0;
My question: is there a way to skip the
in the forAll(timeDirs, timeI)? When I leave out this statement, the program only writes out the velocities from the first time directory. Since I work with quite large meshes, reading the mesh for every time step is very time consuming.
I tried so come around with mesh.readUpdate() but I did not work out...
Thank a lot for your input!
Best regards
sisetrun is offline   Reply With Quote
Old   April 20, 2017, 05:51
Default Default Write Cell Volumes and Velocities for each TimeStep
Max
WildeCat is on a distinguished road
Hi Sisetrum
I do not know a way to get around reading
but what you can do is rewrite to only read the last time instance by removing the forAll and modfying the runTime as shown below. I have not tested this solution, but have written post processing tools in a similar way in the past.
runTime.setTime(timeDirs[timeDirs.size()-1], timeDirs.size()-1);
This should reduce your computing time for only the latest time step, if that suffices you.
Hope I could help
WildeCat is offline   Reply With Quote
Old   April 20, 2017, 06:22
Sebastian Trunk
Hey,
thank you for your reply!
I had something similar to your version. As you said, this gets the data of the last time step...
What I want to get, is a tool that it works in the same way as the sample utility:
Read the mesh only one time to write out the volumes of the cells and extract the velocities from the data in the time directories.
SAMPLE:
Create time
---> CREATE THE MESH
Create mesh for time = 0
Reading set description:
    lineX1
Reading surface description:
    constantPlane
---> SAMPLE ON THE MESH FOR DIFFERENT TIME STEPS
Time = 0
Time = 0.25
Time = 0.37
End
Old   April 20, 2017, 06:32
Default Links to sample
Max
I recommend you look at the sample utility then.
https://cpp.openfoam.org/v3/a04479_source.html
and check how it loads the mesh in "#include "createNamedMesh.H"" before forAll.
Old   April 20, 2017, 06:33
Sebastian Trunk
Thanks, I will give it a try...
Old   April 20, 2017, 06:55
Default Sample code
Max
Hi Sisetrun,
I have taken the liberty to modify your code to import the mesh only once. I think this should work. An idea to speed up your code is not not use "createFields.H" but write in only the variables you need specifically. I have not figured out if createFields or the equivalent variables can be written out of the time loop. To write only the variables you need look at other post processing utilities.
I Hope this helps.
// Description
#include "Time.H"
#include "fvMesh.H"
     // modification end
    mesh.readUpdate();
        #include "createFields.H" //eventually write your own createFields.H
    return 0;
Old   April 20, 2017, 07:29
Sebastian Trunk
Awesome... Thanks a lot for your help!
