Use of nu in simpleFoam
Like Tree1Likes
  • 1 Post By Swagga5aur
Old   June 23, 2017, 07:57
Question Use of nu in simpleFoam
nicky chaigneau
chicky is on a distinguished road
Hello everyone, I am new to cfd especially to openfoam. I try to implement a solver Tsimplefoam wich is simplefoam with temperature fields.
When I discover the file simpleFoam.C I see that the transportProperties was not called. Does it mean that simpleFoam doesn't use nu ? I find it very strange because Navier-Stoke steady-state still have the viscosity parameter.
chicky is offline   Reply With Quote
Old   June 23, 2017, 17:08
Post
Lasse Brams Vinther
Swagga5aur is on a distinguished road
Hello Nicky,
Well the simpleFoam solver does include the nu property from the transportProperties, however, not everything of the solver is defined in the simpleFoam.C folder or createFields. If you consider the options file in the make folder, -I$(LIB_SRC)/transportModels/incompressible/singlePhaseTransportModel \ is included and if you look at the singlePhaseTransportModel.H the following piece of code secures the loading of the nu viscosity:
    IOdictionary
        IOobject
            "transportProperties",
            U.time().constant(),
            U.db(),
            IOobject::MUST_READ_IF_MODIFIED,
            IOobject::NO_WRITE
    viscosityModelPtr_(viscosityModel::New("nu", *this, U, phi))
which is quite similar to the code in the createFields dictionary.
If you want a varying nu model as a function of the temperature you could implement it yourself.
I have attached a TemperatureSimpleFoam solver and a viscosity model, which varies with temperature depending on the specified coefficients.
Hope its of any use and let me know if you have any questions.
Swagga5aur is offline   Reply With Quote
Old   June 24, 2017, 01:46
nicky chaigneau
Thank you very much for your reply. I understand better how it works. Implementing nu as a function of temperature is a great idea to train my self with openFOAM. I will try to do it with your file as a model.
Thank you it is great
Old   September 8, 2018, 20:53
Default using nu nu[...]
fede32's Avatar
Federico Agustín Caccia
fede32 is on a distinguished road
I have found different results in simulations using in transportProperties:
HTML Code:
nu              [0 2 -1 0 0 0 0] 4.43e-5
and
HTML Code:
nu              nu[0 2 -1 0 0 0 0] 4.43e-5
why could be that?
fede32 is offline   Reply With Quote
Old   September 12, 2018, 05:17
Lasse Brams Vinther
Could you perhaps elaborate upon this or attach your case and describe how you have tested this?
Its hard to determine what the reason for this may be without additional information.
Regards Lasse
Old   September 12, 2018, 09:31
fede32's Avatar
Regards Lasse
Sorry, I found that the error was to write nu glued to the bracket, this way:
nu nu[...]
It seems openfoam couldn''t read that and so apply a default value.
Thanks!
Old   September 12, 2018, 10:16
Lasse Brams Vinther
Ah good didn't even notice
Glad that it works now!
fede32 likes this.
simplefoam, solver development, transportproperties
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
MPI error with simpleFoam blaise OpenFOAM Running, Solving & CFD 0 November 7, 2015 14:01
simpleFoam parallel solver & Fluent polyhedral mesh Zlatko OpenFOAM Running, Solving & CFD 3 September 26, 2014 06:53
Laminar simpleFoam and inviscid simpleFoam herenger OpenFOAM Running, Solving & CFD 7 July 11, 2013 06:27
Trying to run a benchmark case with simpleFoam spsb OpenFOAM 3 February 24, 2012 09:07
