How to handle errors in a function object and stop the simulation?
Old   July 24, 2017, 18:10
Default How to handle errors in a function object and stop the simulation?
MakisH is on a distinguished road
I am creating a custom function object, in which I want to have some checks (e.g. in the read() function for the user input) and exit the simulation with an error if something goes wrong.
I managed to output an error, using the FatalErrorIn() macro:
FatalErrorIn("myFunctionObject::myFunction()") << "This is my error message." << nl << exit(FatalError);
This indeed exits the function object, but the simulation continues running, simply without executing the function object's code.
I tried to use the stopAt() method (before the exit()) to stop the simulation manually:
runTime_.stopAt(Time::saNoWriteNow);
but this does not force the simulation to exit with an error code.
How could I stop the simulation from the functionObject, but with a failure exit code?
MakisH is offline   Reply With Quote
Old   September 1, 2017, 12:34
Default How to stop the simulation immediately?
Apart from the fact that OpenFOAM catches the functionObject's errors as "Warnings" (i.e. exiting the functionObject but not the solver itself), I have another relevant question.
The stopAt() method can take one of the following values as an argument:
saEndTime     stop when Time reaches the prescribed endTime
saNoWriteNow  set endTime to stop immediately w/o writing
saWriteNow    set endTime to stop immediately w/ writing
saNextWrite   stop the next time data are written
(see this in the Source Code Guide)
I understand that the saNoWriteNow is the "most urgent" one. However, the solver still performs another iteration and executes the execute() method of the functionObject once more before it finishes.
Is there a better way to stop the simulation immediately? I hope that this is an interesting question.
Old   September 3, 2017, 09:06
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
What if you use abort() instead of exit()?
Zeppo is offline   Reply With Quote
Old   September 3, 2017, 09:18
This works, but is it a good practice? Is it used anywhere else in OpenFOAM or third-party function objects?
I guess you mean the C++ abort(), because I don't find such an OpenFOAM function.
Old   September 3, 2017, 16:23
Zeppo's Avatar
Sergei
When you write
actually you are working with an object FatalError of class error
274 // Global error definitions
275
276 Foam::error Foam::FatalError("--> FOAM FATAL ERROR: ");
Class error is an OF wrapper for termination functions from C. Look at the sources:
https://cpp.openfoam.org/v3/a07673_source.html#l00168
Old   September 4, 2017, 05:46
You are right, there is an OpenFOAM abort(). In the beginning I didn't see that method...
However, it still catches the fatal error as a warning and continues the simulation:
--> FOAM Warning :
    From function bool Foam::functionObjectList::read()
    in file db/functionObjects/functionObjectList/functionObjectList.C at line 675
    Caught FatalError
Old   September 4, 2017, 11:10
A "hacky" way to gracefully stop the simulation would also be to set the end time to the current time (or even to zero):
const_cast<Time&>(runTime_).setEndTime(runTime_.value());
where "runTime_" is the functionObject's reference to the runTime object of the solver.
This will not call any "end()" method of this or other function objects.
Is there any reason to not do it this way?
Old   September 5, 2017, 11:58
I found something interesting:
the behavior I described happens only in the read() method, as the Foam::functionObjectList::read() catches any exceptions.
Using the macro FatalErrorInFunction works normally in the functionObject's execute() and the rest of the methods.
In my case, the code I had in my read() can also go in the start() [correction: start() doesn't exist for a functionObject itself], so my specific problem is solved. Thank you for the help! :-D
edit: Actually it can't, since Foam::functionObjectList::start() simply calls Foam::functionObjectList::read()... :-/
aborting, exit, functionobject, functionobjects, stop simulation
[swak4Foam] some errors in compiling groovyBC in OF220 immortality OpenFOAM Community Contributions 10 April 1, 2013 03:46
