A question on pEqn.C of CavitatingFOAM
Old   September 7, 2017, 09:49
Default A question on pEqn.C of CavitatingFOAM
Byoung Guk Kim
nathan.kim is on a distinguished road
While I am validating the cavitatingFOAM to solve acoustic cavitation under an ultrasonic cavitation device, I have a question on the source code of pEqn.C.
I understand it tries to solve pEqn using variables in the previous time step and update the variables accordingly. So I expect the red marked statement should be
rho = max ( ... )
instead of '=='.
If anybody can tell me if this is correct, before I really change it, it will be so thankful.
BG
---------------(quote begins)-------------------
while (pimple.correctNonOrthogonal())
fvScalarMatrix pEqn
pEqn.solve(mesh.solver(p.select(pimple.finalInnerI ter())));
if (pimple.finalNonOrthogonalIter())
phi += (phiGradp + pEqn.flux())/rhof;
Info<< "Predicted p max-min : " << max(p).value()
<< " " << min(p).value() << endl;
rho == max
psi*p
+ alphal*rhol0
+ ((alphav*psiv + alphal*psil) - psi)*pSat,
rhoMin
#include "alphavPsi.H"
p =
rho
- alphal*rhol0
- ((alphav*psiv + alphal*psil) - psi)*pSat
)/psi;
p.correctBoundaryConditions();
-------------(quote ends)-----------------------------
nathan.kim is offline   Reply With Quote
Old   September 8, 2017, 05:49
Default Question answered by another thread similar as this.
Byoung Guk Kim
I found the operator '==' overrides C/C++ standard operator in another search. The operator is redefined in fvMatrix.
Error in running cavitatingFoam Antonio40 OpenFOAM Running, Solving & CFD 2 February 9, 2015 14:12
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
