September 10, 2017, 18:49 |
Creating Solver
TX
Rep Power: 8 |
Hi
I am trying to create a solver in applications/solvers but the bash displays the message "Permission Denied". Someone with a solution? |
September 11, 2017, 02:21 |
Huipeng Xiao
Rep Power: 8 |
Can you describe your problem more details? and where your openfoam lib installed?
Sent from my Le X620 using CFD Online Forum mobile app |
September 11, 2017, 02:50 |
Pierre HORGUE
Rep Power: 17 |
Hi gulshiraz,
This is probably an issue due to file permissions. By default, if you install opebfoam as a root (using apt-get for example on ubuntu), files in source folders are owned by "root" and only readable. First, you should put your solver-folder in $HOME for example and then replace $FOAM_APPBIN by $FOAM_USER_APPBIN in the file "Make/files" Sincerely, Pierre |
September 17, 2017, 20:10 |
TX
Rep Power: 8 |
The solvers have been by default saved in root directory. Is there a way to access root directory while using bash on Windows?
@Pierre, if you could please provide some more details on it. |
Population Balance Modeling (PBM) - Ansys Fluent | chittipo | FLUENT | 164 | November 18, 2023 11:54 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Creating a new solver from chtMultiRegionFoam | David_010 | OpenFOAM Programming & Development | 0 | April 20, 2010 11:36 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
