New dynamic mesh rule with symbol lookup error
Old   October 2, 2017, 22:42
Default New dynamic mesh rule with symbol lookup error (Solved)
Jue Wang
Joe Wang is on a distinguished road
Hi, Foamers,
I just touched the openfoam programing. I tried to create a new dynamic mesh rule but came across difficulties at the first step.
The development is based on OpenFOAM-extend-4.0.
I tried the followings:
1. I created myMovingBodyTopoFvMesh based on movingBodyFvMesh without any changes but the name and successfully complied (wmake libso) it. I added dynamicFvMeshLibs ("libmyMovingBodyTopoFvMesh.so") to constant/dynamicMeshDict of the case in tutorial and it ran well.
2. Then I created a new meshmotion rule, i.e. mylinearOscillation based on linearOscillation, and successfully compiled (wmake libso) it (no errors show up). Then I changed the linearOscillation to mylinearOscillation in the constant/dynamicMeshDict of the tutorial. But the new mylinearOscillation was not recognized.
3. To solve the problem in 2, I tried the following:
1) I copied the whole solidBodyMotion folder, which contains the linearOscillation folder, as mysolidBodyMotion. I renamed every folders and files and did relevant changes in the Make/files and options. Then they were compiled (wmake libso) successfully.
2) I updated solidBodyMotionFunction with mysolidBodyMotionFunction in the myMovingBodyTopoFvMesh files. I also changed relevant files, including the directory in Make/options. myMovingBodyTopoFvMesh was successfully compiled (wmake libso) then.
3) I made relevant changes in the constant/dynamicMeshDict and ran the tutorial. It gave an error: icoDyMSimpleFoam: symbol lookup error: /home/civil/foam/civil-4.0/lib/linux64GccDPOpt/libmyMovingBodyTopoFvMesh.so: undefined symbol: _ZN4Foam25mysolidBodyMotionFunction3NewERKNS_10dic tionaryERKNS_4TimeE
Does anyone know how to fix it? Really appreciate.
BTW, when I changed the Make/options file, I know how to change the EXE_INC part. But how about the LIB_LIBS part?
When I made the following changes:
EXE_INC = \
-I$(WM_PROJECT_USER_DIR)/src/dynamicMesh/meshMotion/mysolidBodyMotion/lnInclude
LIB_LIBS = \
-lmysolidBodyMotion
the LIB_LIBS change was not recognized. I'm not sure if it's the key problem. But I also noticed I can even delete the LIB_LIBS part and the compilation still worked.
It was really hard for me. Hope anyone could offer me some advice. Thanks.
Joe
Joe Wang is offline   Reply With Quote
Old   October 24, 2017, 21:09
Jue Wang
I solved this problem by changing the Make/options file like
LIB_LIBS = \
-L $(FOAM_USER_LIBBIN) \
-lmysolidBodyMotion
and then it could be corrected built.
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
