Error in Implementation of Pressure-Strain Correlation in SSG Model?!
Old   October 6, 2017, 11:03
Default Error in Implementation of Pressure-Strain Correlation in SSG Model?!
NablaDyn's Avatar
NablaDyn is on a distinguished road
Hello everybody,
studying the SSG Reynolds-stress model on openfoam.com (http://www.openfoam.com/documentatio...8C_source.html) I came across something that confused me. First, the related documentation (http://www.openfoam.com/documentatio...e-ras-ssg.html) is very sparse and maybe also erroneous as it seems to be under construction.
The model equations in the documentation seem to contain a redundant \rho in the second right hand side term (i.e. the first term of the pressure-strain correlation). Also, the documentation, as well as the source code show a sum within the same expression as above
fvm::Sp(((C1_/2)*epsilon_ + (C1s_/2)*G)*alpha*rho/k_, R)
. To my knowlegde
G
is the newtonian gravitational constant with units \mathrm{[m^3/(kg \cdot s^2)]}, whereas
epsilon_
has dimensions \mathrm{[m^2/s^3]}. This looks inconsistent to me. Dimensional analysis of the mentioned expression shows G differs from epsilon_ by the units \mathrm{[kg / (m \cdot s)]} which implies that there is a dynamic-viscosity-like cofactor missing in the G term, since: \mathrm{[kg / (m \cdot s)] \equiv [Pa \cdot s]}
I'm new to the OpenFOAM source code, so please take it easy on me ...
... but is it possible that there's an error in the implementation of the SSG model?
Thanks in advance for any help or comments
NablaDyn is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 04:59
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
