R constant in Perfet Fluid
Like Tree6Likes
  • 1 Post By Mehdi3031
  • 1 Post By anh065
  • 3 Post By wildemam
  • 1 Post By Tobermory
Old   October 30, 2017, 10:16
Default R constant in Perfet Fluid
Mehdi Aminyavari
Mehdi3031 is on a distinguished road
Hello everybody,
in many cases of openFoam, you can find equation Of State that is modeled as a perfect Fluid such as in:
tutorials/multiphase/compressibleMultiphaseInterFoam/laminar/damBreak4phase/constant/thermophysicalProperties.mercury
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectFluid;
    specie          specie;
    energy          sensibleInternalEnergy;
mixture
    specie
        nMoles      1;
        molWeight   200.59;
    equationOfState
        R           6818;
        rho0        13529;
    thermodynamics
        Cp          139;
        Hf          0;
    transport
        mu          1.522e-3;
        Pr          0.022;
or in:
tutorials/multiphase/reactingTwoPhaseEulerFoam/laminar/bubbleColumn/constant/thermophysicalProperties.water
thermoType
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
mixture
    specie
        nMoles      1;
        molWeight   18;
    equationOfState
        R           3000;
        rho0        1027;
    thermodynamics
        Cp          4195;
        Hf          0;
    transport
        mu          3.645e-4;
        Pr          2.289;
There are two parameters "R" and "rho0" that are defined and necessary for perfect liquid model which is defined in OF documentation as following:
I can't figure out what is this value of R which is 3000 for water and 6818 for mercury and how to calculate it for ammonia for example. any Idea?
saidc. likes this.
Mehdi3031 is offline   Reply With Quote
Old   February 7, 2018, 03:10
Default I don't know, either. Any one know the answer?
meshman is on a distinguished road
There is no documentation related above question...
meshman is offline   Reply With Quote
Old   March 6, 2018, 00:45
Jie
jiejie is on a distinguished road
Originally Posted by Mehdi3031 View Post
Hello everybody,
thermoType
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
mixture
    specie
        nMoles      1;
        molWeight   200.59;
    equationOfState
        R           6818;
        rho0        13529;
    thermodynamics
        Cp          139;
        Hf          0;
    transport
        mu          1.522e-3;
        Pr          0.022;
or in:
thermoType
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
mixture
    specie
        nMoles      1;
        molWeight   18;
    equationOfState
        R           3000;
        rho0        1027;
    thermodynamics
        Cp          4195;
        Hf          0;
    transport
        mu          3.645e-4;
        Pr          2.289;
Hi Mehdi
I am having the same problem. I could not figure out the R of 3000 for water in the twoPhaseEulerFoam tutorial. In particular with respect to rhom (after you run the case) RAS/bubbleCoumn, rhom is around 1027 in the region where alpha.air=0 (meaning water) but rhom is around 513 in the region where alpha.air=1 (meaning air). Shouldn't the rhom be around 1.225 (density of air) in the region where alpha=1?
Thanks
Jie
jiejie is offline   Reply With Quote
Old   May 1, 2018, 09:58
krishnan
tankerp is on a distinguished road
Im also having a difficulty in understanding this. What is rhom and why is it as much as 513 in the region representing air?
tankerp is offline   Reply With Quote
Old   June 6, 2018, 18:01
Anh
anh065 is on a distinguished road
R = R_{gas}/MW with MW being the molecular weight of gas/fluid.
For air, MW\approx 0.029 [kg/mol] and R =8.314/0.029\approx 287 [J/kg.K].
https://en.wikipedia.org/wiki/Ideal_gas_law
jiejie likes this.
anh065 is offline   Reply With Quote
Old   June 19, 2018, 05:55
Question I don't think so, because..
According to your solution,
For example, in case of water (H2O)
the molar mass is about 0.018 kg/mol
so the R = 8.314/0.018 ~ 461.9 J/kg K.
This value is not same with '3000' in the above tutorial.
(Actually, I still don't know why the value is 3000....)
Old   February 1, 2019, 06:04
Arne
arsimons is on a distinguished road
I believe that in OpenFOAM 1806, R = 7255 for water. However, I have no idea what it means...
arsimons is offline   Reply With Quote
Old   August 17, 2019, 09:24
Joachim Herb
jherb is on a distinguished road
Have you solved this?
I think if you use R for a liquid, it is just some kind of compressibility of it.
Regarding rhom: It is calculated here:
https://github.com/OpenFOAM/OpenFOAM...Epsilon.C#L403
and it involves the use of a virtual mass model. What are the corresponding settings in your case?
jherb is offline   Reply With Quote
Old   May 9, 2020, 00:22
M Shaaban
wildemam is on a distinguished road
If anyone is still wondering:
R is (RT)^(-1)
For water, it should be calculated from psi, the compressiblity.
psi = rho/bulk modulus, giving around 4.5e-7 s2/m2
(check here https://www.openfoam.com/documentati...x12-620003.3.1)
then R = 7255.
the use of 3000 is a mystery.
parthigcar, saidc. and Lennart.H like this.
wildemam is offline   Reply With Quote
Old   February 13, 2021, 15:56
Xingchun Wang
krasus is on a distinguished road
R is (RT)^(-1)
then R = 7255.
Thanks for the clue. However, can you show how to calculate R from psi? I can't figure out how (RT)^-1 and psi is correlated.
krasus is offline   Reply With Quote
Old   February 15, 2021, 05:04
Tobermory will become famous soon enough
psi is defined as drho/dp|_T, and so for an ideal gas psi = rho/p = 1/RT. This is referred to as the compressibility. R is the ideal gas constant over the molecular weight; it doesn't have any meaning for a liquid.
cjacob likes this.
Tobermory is offline   Reply With Quote
Old   February 20, 2021, 00:30
Xingchun Wang
Thanks for the info!
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 05:07
Ideal gas a and constant density fluid sunilpatil Fluent Multiphase 0 May 25, 2016 13:24
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
