calculating wall distance wallDist
Like Tree3Likes
  • 1 Post By su_junwei
  • 1 Post By benk
  • 1 Post By benk
Old   April 28, 2010, 03:43
Default calculating wall distance wallDist
Volker Tritschler
volker is on a distinguished road
hi all,
I need to calculate the nearest wall distance within a solver code to add a damping function. I know that there is a tool wallDist that does the job. and in order to make use of wallDist one has to include the wallDist.H file.
But somehow I'm failing to call the function in the right way.
I went through some code files and within the turbulence models they always put:
#include "wallDist.H"
wallDist y_;
in order to create a volScalarField y_ which gives the distance to the nearest wall.
thanks for any help!
greets, volker
volker is offline   Reply With Quote
Old   April 28, 2010, 04:17
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
Hi volker
Please try the
volScalarField y = wallDist(mesh).y();
y is the distance to the nearest wall.
Junwei
su_junwei is offline   Reply With Quote
Old   April 29, 2010, 07:46
Claus Meister
idrama is on a distinguished road
Hey Foamers!
I have a similar problem: I want to the velocity vector for the first node point to the wall. Can I use wallDist.H somehow?
Cheers
idrama is offline   Reply With Quote
Old   April 29, 2010, 08:24
Volker Tritschler
I'm calling wallDist.H as Junwei suggested. but on solver-level it doesn't seem to work. actually not due to the call of wallDist.H (which seems to be correct) but due to some header file which cannot be found.
maybe someone has an idea how to get rid of that problem, or how to get the wall distance within a solver code in an accurate way?
many thanks and greets
volker
Old   April 29, 2010, 11:26
su_junwei's Avatar
su junwei
Originally Posted by idrama View Post
Hey Foamers!
Cheers
wallDist used the cell center when calculating the distance not the mesh points.
Junwei
lpz456 likes this.
Old   May 10, 2010, 11:09
Ben K
benk is on a distinguished road
I need the distance from the wall for my solver but when I compile my solver I get this error under 1.5-dev:
/usr/local/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude/wallDist.H:66:27:error: cellDistFuncs.H: No such file or directory
When I search for cellDistFuncs.H, I find it in this directory:
/usr/local/OpenFOAM/OpenFOAM-1.5-dev/src/meshTools/cellDist
Does anybody know how to fix this?
benk is offline   Reply With Quote
Old   May 10, 2010, 12:15
Volker Tritschler
yes, I had the same problem under 1.6.x. but couldn't manage to solve it.
maybe someone can help us!
cheers, volker
Old   May 10, 2010, 13:23
Ben K
I think this is the fix for 1.6.x at least:
http://www.cfd-online.com/Forums/ope...stfuncs-h.html
I'm guessing it's the same for 1.5-dev as well.
JasonWang3 likes this.
Old   May 12, 2010, 14:29
Ben K
Try adding this to your Make/options file:
EXE_INC = -I$(LIB_SRC)/meshTools/lnInclude \
chen wang likes this.
Old   April 29, 2015, 17:10
Default Streamwise distance
pooyan
sam1364 is on a distinguished road
How can we change some parameter based on the streamwise location? Do we have same thing as wallDist.H for streamwise variations?
sam1364 is offline   Reply With Quote
Old   May 1, 2015, 11:34
Xinguang Wang
JasonWang3 is on a distinguished road
cheers, volker
Hi Volker
I met the same problem. I copy the kOmegaSST model and rename it and then build it. It's no problem. But in my case, it's wrong like yours.
Have you solved this problem?
jason
JasonWang3 is offline   Reply With Quote
Old   May 1, 2015, 11:54
Xinguang Wang
This file is in the option file. I don't think this is the key to this problem.
Old   December 28, 2017, 11:29
Sangeet
sangeet is on a distinguished road
I also need the nearest wall distance for applying wall boundary condition to Omega in kOmegaSST turbulence model, can someone help me on exactly how to get this value?
Thank You
sangeet is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
distance to wall in given direction nikwin OpenFOAM 3 February 16, 2012 09:27
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
