Multiple Inlets Adjoint
Old   November 20, 2018, 11:43
Exclamation Multiple Inlets Adjoint
Massachusetts
kayla1994 is on a distinguished road
Hello everyone,
I'm trying to modify the shapeOptimizationFoam in order to account for multiple inlets. In the original createFields.H file there is a line of code that is used to set a zero alpha at the inlet
const labelList& inletCells = mesh.boundary()["inlet"].faceCells();
which i changed with
const labelList& inletCells1 = mesh.boundary()["inletLeft"].faceCells();
const labelList& inletCells2 = mesh.boundary()["inletRight"].faceCells();
and I also added
zeroCells(alpha, inletCells1);
zeroCells(alpha, inletCells2);
after the definition of alpha. Am i doing it right? The solver complied correctly without any problems.
I run the simulation and at the beginning I had this strange warning line and the simulation stopped at the first iteration of the adjoint problem.
Reading field pa
--> FOAM Warning :
    From function const Foam::HashTable<Foam::List<int>, Foam::word>& Foam::polyBoundaryMesh::groupPatchIDs() const
    in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 455
    Removing patchGroup 'wall' which clashes with patch 6 of the same name.
This is strange because, before the simulation, I tested the mesh with simpleFoam to initialize the solution. Any idea of what is this problem?
Thank you for your help
kayla1994 is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Shape optimization doesn't converge - Adjoint log file JPBLourenco SU2 Shape Design 0 December 11, 2017 08:41
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Multiple inlets problem Jeff Main CFD Forum 2 August 17, 2005 10:48
Multiple Inlets Charlie V FLUENT 0 May 28, 2001 02:29
